TANG BAND T1-1925S Speaker Module Full Range 1W 4 Ohm (The pair)
TANG BAND T1-1925S Speaker Module (Pair)
Reference : 11701
28,90 €tax incl.
24,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
The TANG BAND T1-1925S speaker module features a dome speaker with elastomeric diaphragm on wide excursion rubber suspension. It works in conjunction with a passive radiator type elliptical.
This solution delivers wide-spread sound in a compact, aggressive, spatially aggressive sound with a high bandwidth (150Hz - 20000Hz).
The Tang Band module is ideal for the design of portable devices, sound bars, or multimedia terminals.
Features:/ Strong>
  • Nominal dome speaker diameter: 25mm
  • Power Handling (RMS): 1 Watts
  • Power Rating (Max): 2 Watts
  • Impedance: 4 Ohm
  • Frequency response: 150Hz - 20,000Hz
  • Sensitivity: 76 dB, 1W / 1m
  • Coil Diameter: 13.28mm
  • Resonant Frequency (Fs): 78Hz
Building materials:
  • Dome: Elastomer
  • Material of suspension: Rubber
  • Neodymium magnet
  • Case: Polymer
  • Black Finish
Dimensions and weight:
  • 85x29x14.1mm
  • Weight unit: 41.5g
  • Sold by pair
Plan Tang Band HP
Speaker Power (W RMS)1.0
Speaker TypeFull range
Impedance (Ω)4
Loudspeaker diameter (mm)25.0
Diaphragm typeElastomer
Efficiency / Sensitivity (dB)76.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)150
Highest frequency (Hz)20000
Robert / NL
Quick delivery, reasonable shipping costs.
This product is hard to find in Europe, but exactly what I needed. SuperB that Audiophonics has it on stock!
https://youtu.be/I3fcfhaJILE
This review has been posted for TANG BAND T1-1925S Speaker Module Full Range 1W 4 Ohm (The pair)
