MONACOR MDM-2 Speaker Damping Polyester 130g 63x33x3.5cm (Set x2)
Mousse Absorbante Blanche polyester pour enceintes
This environmentally friendly damping material for thermal and sound insulation is made of 100% Polyester fibres. It is therefore ideal as a sound absorber to be installed inside the body of a loudspeaker.
Reference : 1365
8,50 €tax incl.
7,08 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Monacor MDM-2
Absorbant pour Enceintes Polyester 130g 63 x 33 x 3.5cm (Set x2)
This environmentally friendly damping material for thermal and sound insulation is made of 100% Polyester fibres. It is therefore ideal as a sound absorber to be installed inside the body of a loudspeaker. It is also particularly convenient to apply as it does not cause irritation to the eyes, skin or respiratory tract.
MDM-2 contains no chemicals or additives. It is hypoallergenic, easy to install, totally stable and 100% recyclable.
It is also characterised by excellent insulation values, low flammability, high resistance to UV light, as well as to mould and dust mites.
Measurements in reverberation chamber :
FrequencySound absorption rate
100Hz0.37
125Hz0.47
160Hz0.75
200Hz0.78
250Hz0.99
315Hz0.0.94
400Hz1.10
500Hz1.10
630Hz1.08
800Hz1.03
1000Hz1.04
1250Hz0.99
1600Hz1.03
2000Hz1.03
2500Hz1.06
3150Hz1.05
4000Hz1.04
5000Hz1.06
Product typeSpeaker damping
MaterialPolyester
Dimensions63 x 33 x 3.5cm
Temperature range0°C - 40°C
Weight130g
ColorWhite
QuantitySold by 2
MaterialPolyester
Complément amorti synthétique, obstruction des évents.
Je l'utilise en complément d'amortissant interne d'enceintes tout en bas, bourrage du bas de l'enceinte, me permet de boucher les évents en laissant le passage de l'air grâce à son faible amorti.
Pour les parois internes, je mets la plaque en feutre Jantzen amortissant de 1mx1m bien plus absorbante et hautement qualitative.
This review has been posted for MONACOR MDM-2 Speaker Damping Polyester 130g 63x33x3.5cm (Set x2)
This environmentally friendly damping material for thermal and sound insulation is made of 100% Polyester fibres. It is therefore ideal as a sound...
