Pytaudio PYT Panel Multilayer Absorbent 400x400
As a result of a specific development, these acoustic panels, as elegant as they are efficient, eliminate the resonances of the listening place in order to maximize the potential of your Audio installation.
Its double-skin structure with heterogeneous densities of 275 kg / m3, 170 kg / m3 and 40 kg / m3 gives it maximum performance at minimum weight and thickness.
Thethe installation of these panels makes it possible to find easily and quickly more softness and a better balance of restitution.
Installation:
The panel PYT panel can be installed on any type of support in a few seconds.
The back of the panel is self-gripping (velvety type) over its entire surface, it is possible to hang it everywhere thanks to the adhesive patches provided.
The panel also has a metal eyelet integrated into its back. This makes it possible to hook it by means of the spherical pin provided in a sufficiently soft support (placo, wood ...) without risking deterioration of a surface that would be more fragile with the adhesive patch (wallpaper for example). Any kind of small nail or tip may also be suitable.
Caracharacteristics:
Optimal applications:
recto
Back
Quick fixing by Scratchs stickers
