PINTA AMORTSONBi10A PHD Self-adhesive bitumen backing 400x500mm
PINTA Amortson Bi10A PHD - Amortissant bitume autoadhesif 400x500
4.8 / 5
Reference : 5408
9,90 €tax incl.
8,25 € tax excl.
The minimum purchase order quantity for the product is 3
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
The minimum order quantity for this product is 3.
The Amortson® Bi are particularly suitable for damping sheet, plate, metallic objects or plastics excited by solid or air.
They are also used to reinforce wall insulation by the combined effects of mass supply and damping on coincidence phenomena.
Amortson® Bi should be applied at a temperature above 18 ° C. It is even recommended to preheat it to 30 ° C.
After application, Amortson® Bi should be strongly reinforced (2 Kg / dm²).
The substrates to be treated must be free of oil, grease, moisture and dust.
Weight per square meter:
Bi 3A PHD: 3 kg / m² -> 0.55kg / plate of 400x500 (thickness 1.6mm)
Bi 5A PHD: 5 kg / m² -> 1kg / plate of 400x500 (thickness 2.7mm)
Bi 10A PHD: 10 kg / m² -> 2.4kg / plate of 400x500 (thickness 5.0mm)
Datasheet as PDF
MaterialBitumen
11 reviews
Parfait
Utilisé pour amortir et lester une enceinte imprimé en 3D.
Délais de livraison respecter comme d'habitude
This review has been posted for PINTA AMORTSONBi10A PHD Self-adhesive bitumen backing 400x500mm
Produit Amortson
Produit conforme, pas de surprise.
Je me suis livré à plusieurs achats chez Audiophonics ces deniers mois.
Sans aucune exception, service parfait, et délai de livraison plus court que celui annoncé...
Really helped to dampen cabinet resonances in my speakers
Not an easy material to cut, but this really helped to dampen cabinet resonances in my speakers. So I'm very happy.
I used the thickest ones, by the way.
Efficace
Utilisé pour alourdir les portières de mon coupé, fonctionne très bien pour atténuer la résonance de la tôle.
Moins de bruit au roulage et graves des HP renforcés.
En réponse au 1er avis de "felix q.", une plaque de bitume disposée sur votre lecteur Blu-Ray ne va pas transformer les informations numériques et rendre les basses "franches et sèches"... C'est de la folie, merci d'éviter la désinformation.
OPPO Signature l'a fait dans le seul but d'éviter à la tôle de vibrer (lecteur + capot supérieur).
Si vous partez dans cet optique, le capot de votre TV vibrera avant celui de votre Lecteur Blu-Ray...
Sur une Rega 3
J'avais déjà acheté la même plaque bitumée. Les 2 m'ont servi pour amortir une vieille platine Rega 3. J'ai posé une plaque dessus et l'autre dessous en pratiquant des découpes là où il fallait. Cela n'empêche pas le fonctionnement de la platine. Une de mes meilleures améliorations de cette platine qui n'en finit pas de me surprendre!
