PINTA AMORTSON Bi5A PHD Self-Adhesive Bitumen Damping 400x500mm
PINTA Amortson Bi5A PHD - Amortissant bitume auto-adhesif 400x500
4.9 / 5
Reference : 5187
8,90 €tax incl.
7,42 € tax excl.
The minimum purchase order quantity for the product is 3
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
The minimum order quantity for this product is 3.
Amortson® Bi are self-adhesive viscoelastic sheets.
The Amortson® Bi are particularly suitable for damping sheet, plate, metallic objects or plastics excited by solid or air.
They are also used to reinforce wall insulation by the combined effects of mass supply and damping on coincidence phenomena.
Amortson® Bi should be applied at a temperature above 18 ° C. It is even recommended to preheat it to 30 ° C.
After application, Amortson® Bi should be strongly reinforced (2 Kg / dm²).
The substrates to be treated must be free of oil, grease, moisture and dust.
Weight per square meter:
Bi 3A PHD: 3 kg / m² -> 0.55kg / plate of 400x500 (thickness 2mm)
Bi 5A PHD: 5 kg / m² -> 1kg / plate of 400x500 (thickness 2.7mm)
Bi 10A PHD: 10 kg / m²
Datasheet as PDF
MaterialBitumen
17 reviews
Top anti-vibrations.
Et ça colle fort, impossible de le replacer après application.
Super plaque de bitume pour intérieur d'enceintes, caissons de basses et même platine vinyle ou lecteur CD.
Découpée au cutter c'est vraiment bien.
Plaques livrées en 24 heures chrono !!
This review has been posted for PINTA AMORTSON Bi5A PHD Self-Adhesive Bitumen Damping 400x500mm
Hello, good quality of the article. Fast shipping to Spain...perfect!!!
Good stuff
Not much to say about it it damps metal sheet very well so it will work on you Thorens TD1..sub chassis as damping material just have a look at the 160S innards and see what the factory did for ideas.
Large un-damped metal CD player parts are also a good candidate just be careful not to block the laser unit in any way.
Parfait
Très bon produit et livraison ultra rapide!
Merci à l’équipe d’Audiophonics :)
parfait
facilité de mise en oeuvre, fait le job.
