SOMMERCABLE GRINDYCOP BEAST Unbalanced cable shielded OFC 1x0.35mm² Ø 6mm
Reference : 9924
7,90 €tax incl.
6,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
asymmetrical, double screen
SOMMER CABLE - SC-GRINDYCOP BEAST
This well polished cable ...
is a sensation on the market.
A high-end professional cable with a very individual design: it is composed of polished copper conductors, as used for example in high-performance industrial transformers. In order to optimize the conductive capacities, the surface of the copper (type OFC class 6, degree of purity = 99.9999%) undergoes fine polishing, and the wires are then isolated using a special electrical insulating varnish of high quality. The outer jacket is made of very strong PVC, non-stick and resistant to UV rays.
The advantageacoustic system of this design is an extremely fast analytical transmission (ideal for attacks), accompanied by an excellent imposition of mediums and very pronounced bass.
The cablee GRINDYCOP BEAST is perfectly suited for the low frequencies of analog devices, but also for the sharp treble of virtual synthesizers.
ADVANTAGES:
  • Tone of guitars, basses and keyboards extraordinarily fast, precise and imposing, obtained by the special polishing of copper conductors (type OFC, class 6)
  • Double shielding, consisting of a copper helical coil and a conductive carbon screen
  • Low capacity, little loss of retransmission
  • Very strong and resistant to crushing due to the special PVC sheath and dense shielding
  • USE:
    • High-end reference cable for guitar, suitable for studio and stage use
    • Asymmetrical cable for keyboards, samplers, mixing tables, etc.
    Specifications:
    ConstitutionLI2Y (LS) CY ... x0,35mm²
    Envelope, diameterPVC 6.5 mm
    AWG22
    Conductor inside1 x 0.35 mm2
    Brass Cu per core40 x 0.1 mm
    Insulation of the conductorFoam / Skin PE 3.1 mm
    ProtectionTinned copper braid + semiconductor
    Optical cover100%
    Operating temperaturemin. -30 ° C
    Operating temperaturemax. 70 ° C
    Fire resistance per m0.26 kWh
    Weight per m62 g
    Packaging unit, packing unitper meter
    Colortransparent, red / green
    Charelectrical properties:
    Metric Capacity Screen / Display88 pF
    Odometer Resistance, Conductor<55 Ohm
    Resistance, insulation> 10 GOhm
Length (m)Sold by length
Number of conductors1
Insulation materialPVC
ShieldingYes
