Wireless Receiver Bluetooth 4.0 aptX NFC Digital Output
Wireless Audio Receiver Bluetooth APTX NFC Digital Output
Reference : 8441
51,90 €tax incl.
43,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
Here is finally a solution that many of us expected, this small receiver has the ability thanks to the technology used to allow wireless transfer of music stream in CD quality.
This ultra-modern receiver has an analog output and an optical digital output to connect directly to a converter for even more audio quality.
Compatible with all Bluetooth 4.0 AD2P devices, it offers a CD-audio quality reproduction thanks to a low compression ratio. Thus, FLAC, Apple Lossless or PCM audio files are rendered almost perfectly. When files natively in MP3 or AAC (with a rate less than 350Kbits / sec), they are transmitted without decoding and without any degradation.
Ofthe compact design and ease of implementation, this receiver will allow you to listen to your favorite songs on your audio system from any Bluetooth source.
selft the vast majority of Smartphone, Tablet PC, Iphone, Ipad ...
Specifications:
  • NFC (Near Field Contact) Simplified pairing by approaching the transmitter (for compatible devices)
  • Outputs: Analog RCA Stereo, Digital Optical Toslink and Coaxial
  • Signal Noise Ratio: 120 dB
  • NForetek N2311 DSP / DAC / Bluetooth Module
  • Bluetooth: 4.0 apt-X (+ AD2P)
  • Possibility of pairing 5 devices simultaneously
  • Profiles: AD2P and AVRCP
  • Output change: By switch under the device
  • Range: 15 m class II
  • Color: Black
  • Dimensions 80 x 80 x 30 mm
  • Comes with its transformer, a digital optical cable, a jack / RCA and RCA / RCA cable
https://www.audiophonics.fr/images2/6518/6518_ADVANCEWTX500_4.jpg
Illustration (amplifier and speakers not included)
https://www.audiophonics.fr/images2/8441/8441_BTS_WIRELESS_BLUETOOTH_APTX_3.jpg
4 reviews
Parfait, au niveau son, je ne ressent pas de différence avec ma platine cd classique... Pas de souffle ou de bruit anormal, connections des appareils simple et rapide, je recommande à tout ceux qui veulent passer au 21eme siècle ;)
This review has been posted for Wireless Receiver Bluetooth 4.0 aptX NFC Digital Output
Presque parfait !
l'appareil est super mais le bouton marche / arrêt est manquant.
Expérience d’achat Recepteur aptX NFC/Dongle aptX
Pour ce qui est du récepteur, l’appairage (pas de NFC en ce qui me concerne) ne pose pas de problème à condition d’être très proche de lui lors de l’opération. Il y a ensuite connexion automatique régulière.
Le pilote fourni avec le dongle n’a pas fonctionné correctement sur mon ASUS i5 Windows 10 (pas de connexion auto et perte de l’appairage après extinction du PC). Il y a donc eu une grande perte de temps pour son installation. J’ai fini par utiliser pilote et paramétrage de W10 sans me soucier du driver fourni.
Pour finir l’essentiel : le son. Il me convient et la combinaison aptX/Flac est effectivement très proche du CD audio.
Je suis donc satisfait de mes achats.
il fait le boulot
Très bon récepteur, connecté en coaxiale au convertisseur technics sh-x1000 de ma platine cd
J'ai comparé un cd (opeth pale communion) et le même fichier en 320 kbps en bluetooth
Difficile de trouver une différence !
Merci à david d'audiophonics pour le conseil.
