NEUTRIK NC3MX-SOM 3 Pins Male XLR Connector Gold Plated Ø8mm (Unit)
The Neutrik NC3MX is a 3-pole male XLR connector with zinc body and gold plated contacts. It is easy to assemble and consists of only 4 parts with a robust die-cast shell, a fiberglass-reinforced hard plastic insert and a chuck-type strain relief for secure clamping of all cables.
Reference : 791
7,40 €tax incl.
6,17 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Neutrik NC3MX
Neutrik NC3MX Connecteur XLR Mâle 3 Pôles Plaqué Or Ø8mm (Unité)
The Neutrik NC3MX is a 3-pole male XLR connector with zinc body and gold plated contacts. It is easy to assemble and consists of only 4 parts with a robust die-cast shell, a fiberglass-reinforced hard plastic insert and a chuck-type strain relief for secure clamping of all cables. The soft rubber end cap offers high protection against bending stress.
Product typeMale XLR connector
Suitable cable diameterØ3.5 - 8mm
Max conductors section2.5mm² (14AWG)
Mounting typeTo solder
Lifetime> 1000 cycles
Tip materialPolyurethane
Contacts platingGold 2µm
Contacts materialCopper alloy
Insert materialPolyamide
Locking element / shell materialZinc
Shell platingNickel
Temperature range-30°C / +80°C
StandardsUL 94 V-0
IEC 61076-2-103
IP40
IEC 68-2-20
Capacitance between contacts≤4pF
Contacts resistance≤3mΩ
Dielectric strength1.5kVdc
Insulation resistance> 10GΩ
Rated current per contact16A
Rated voltage< 50V
Insertion / withdrawal strength≤ 20N
Total dimensionsØ19.4 x 67mm
Insulation materialPE
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
Très bon produit
Qualité Neutrik fabriqué pour Sommer afin d'utiliser leurs câbles de Diamètre 8 mm. Contacts plaqués Or.
This review has been posted for NEUTRIK NC3MX-SOM 3 Pins Male XLR Connector Gold Plated Ø8mm (Unit)
The Neutrik NC3MX is a 3-pole male XLR connector with zinc body and&nbsp;gold plated contacts. It is easy to assemble and consists of only 4...
