AC Adapter 100-240V to 7V 3A DC
11471
9,90 €tax incl.
8,25 € tax excl.
This product is no longer in stock
Here is an AC adapter Power supply 100-240V AC to 7V 3A DC jack 2.1mm. Ideal for replacing your faulty or disconnected battery or equivalent charger. Can also be used as a power supply for your DIY projects and fixtures, which often require precise voltages.
Voyou also have the option of removing the base plug and adding a socket of another size.
Features:/ Strong>
  • Switching power supply compatible with a mains voltage of 100 to 240V AC (50-60Hz)
  • Output in: 7V - 3A (3000mA) DC
  • Output Jack Diameter of Output: External 5.5mm / Internal 2.1mm (Compatible 2.5mm also)
  • Dimensions: 92 x 46 x 35mm
  • Weight: 138g
  • Cable length: 1,10m (110cm)
  • CE compliant
  • Color: black
ColorNoir
Colissimo - TNT - SoColissimo
