Aviation type Toggle Switch 2 pole 2 positions 250V 15A
Aviation type Toggle Switch 2 pole 250V 15A
9,90 €tax incl.
8,25 € tax excl.
This high quality switch gives you the ability to switch, select a function easily.
Connection by flat connector for terminal or welding.
Black housing, metal switch with toggle On / On.
Characteristics :
  • Aviation type flip-flop
  • 2 poles
  • On / On, 6 pin
  • Connectors: Brass
  • Aluminum plate
  • Display On / On
  • Switching capacity 250V, 15A
  • Operating Temperature Range: -25 to 85 ° C
  • Number of cycles: 20000
  • Fastening by solder or lug 6mm
  • Mounting Diameter: 12mm
  • Panel Thickness: 5mm
  • Dimensions: 34x19.5x53mm
  • Weight: 30g
Illustration of different types of switch operation.
Colissimo - TNT - SoColissimo
