This digital caliper lets you perform length measurements with high accuracy (0.1mm)
It is equipped with a button for switching between a display in mm (millimeters) and a measurement in inches (inches)
A second zero button is used to calibrate the foot after re-closed position. This operation ensures that each measure will be of maximum accuracy.
An on / off button is used to save battery (not included) when the camera is not in use.
Measured | 0-200mm |
Viewing | mm / inches |
Screen | LCD |
Resolution | 0.1mm |
Precision | 0.1 mm |
Function reset | Yes |
Food | 1,5V LR44 |
Material | Carbon fiber |
