High Speed Steel (HSS) and Cobalt 5% ⌀4.2mm
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection against heat. Taking advantage of a double helix structure, the drill bit can be used longer than a conventional drill by promoting chip evacuation. It is suitable for drilling on alloyed or non-alloy steel, stainless steel, cast steel, cast iron or heat and acid resistant metals. The drill bit is equipped with a cylindrical shank of the same diameter as the screw drills or drill stands.
Drill type | Double twist metal drill |
Material | High Speed Steel (HSS) and Cobalt 5% alloy |
Diameter | 4.2mm |
Total length | 64.6mm |
Shank type | Cylindrical |
Quantity | 1 (Unit) |
