High quality Soldering iron 30W 420°C Ø5.8mm
Reference : 10913
14,90 €tax incl.
12,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
This soldering iron is perfect for all your DIY assemblies and projects, it is thus ideal to begin in welding. Its maximum temperature is 420 °, it is a thermostatic iron.
The power of 30W is specially adapted to weld electronic components on printed circuit boards (PCB).
This soldering iron plugs directly into the mains. It also comes with a small support for soft aluminum iron.
Characteristics :
  • Automatic Heat Adjustment
  • Maximum temperature of 420 ° C
  • Power : 30 Watts
  • Max. Acceptable Failure Diameter: Ø5.8mm
  • Power supply: 110V / 60Hz or 220V / 50Hz
  • Impedance: <2Ω
  • Dimensions: 246 x 23.6 x 6.5 mm
  • Weight: 164g
  • Color: Gray / Blue
