High quality Soldering iron 60W 470°C Ø5.8mm
Fer à souder 60W 470°C
4.0 / 5
Reference : 10914
19,90 €tax incl.
16,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
This soldering iron is perfect for all your DIY assemblies and projects, it is thus ideal to begin in welding. Its maximum temperature is 470 °, it is a thermostatic iron.
In addition to being suitable for soldering electronic components to printed circuits (PCBs), the power of 60W also makes it possible to make small, more complex metal welds.
This soldering iron plugs directly into the mains. It also comes with a small support for soft aluminum iron.
Characteristics :
  • Automatic Heat Adjustment
  • High of 470 ° C
  • Power : 60 Watts
  • Max. Acceptable Failure Diameter: Ø5.8mm
  • Power supply: 110V / 60Hz or 220V / 50Hz
  • Impedance: <2Ω
  • Dimensions: 246 x 23.6 x 6.5 mm
  • Weight: 164g
  • Color: Gray / Yellow
Bonne qualite
Très bien, léger et maniable, indicateur de chauffe
Un seul regret, il n est pas livre avec le support tel que dit dans la description.
Livraison parfaite
This review has been posted for High quality Soldering iron 60W 470°C Ø5.8mm
