Soldering iron with LCD 60W 450°C Ø5.8mm
10915
39,90 €tax incl.
33,25 € tax excl.
Available
Shipping date: 22-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
This soldering iron is perfect for all your DIY assemblies and projects, it is thus ideal to begin in welding. Its temperature can be adjusted via its LCD screen between 80 and 450 ° C, allowing you to choose precisely the desired heat according to the application of the moment.
In addition to being suitable for welding electronic components on printed circuit boards (PCBs), it can also be used to make small, more complex metallic welds.
Characteristics :
  • Digital display LCD temperature display
  • Adjustable temperature: from 80 to 450 ° C maximum
  • Accuracy at plus or minus 2 ° C
  • Fast heating speed: approx. 8 seconds
  • Power: 60 Watts
  • Max. Acceptable Failure Diameter: Ø5.8mm
  • Power supply: AC 220V / 50Hz
  • Impedance: <2Ω
  • Dimensions: 246 x 23.6 x 6.5 mm
  • Weight: 170g
  • Color: Gray / Black
Colissimo - TNT - SoColissimo
