Soldering iron with LCD 90W 480°C Ø5.8mm
Reference : 11277
42,90 €tax incl.
35,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
This soldering iron is perfect for all your DIY assemblies and projects, it is thus ideal to begin in welding. Its temperature can be adjusted via its LCD screen between 50 and 480 ° C, allowing you to choose precisely the desired heat depending on the application.
In addition to being suitable for soldering electronic components on printed circuit boards (PCB), it can also be used to make small metal welds a little more advanced thanks to its power of 90W.
This soldering iron plugs directly into the AC outlet.
Characteristics :
  • Digital display LCD temperature display
  • Adjustable temperature: from 50 to 480 ° C maximum
  • Accuracy at plus or minus 2 ° C
  • Fast heating speed: approx. 8 seconds to reach 350 ° C
  • Power: 90 Watts
  • Max. Acceptable Failure Diameter: Ø5.8mm
  • Power supply: AC 220V / 50Hz
  • Impedance: <2Ω
  • Dimensions: 246 x 23.6 x 6.5 mm
  • Weight: 170g
  • RoHS Certified
  • Color: Black / Red
