ALLO aluminum case for DigiOne player and Raspberry Pi
Reference : 13253
49,92 €tax excl.
Aluminum Housing for ALLO Digione player
Housing only
This 100% aluminum casing is designed to dress up and protect your ALLO Digione player.
Its construction entirely aluminum protects yout device from electronic interference and noise while providing good heat dissipation.
In the same way, the middle segment has a heatsink for passive cooling: it reduces from 15 to 30% the processor core temperature, which is a significant improvement in terms of reduction of distortion and enhancement of audio performance.
This accessory comes with floating stands that can be mounted on silicone. Those stands contribute to reduce hardware vibration.
Mounting video
TypeHousing
MaterialAluminum (AL6061)
InstallationA self-assembly
Number of elements to assemblex3
passive coolingYes
Anti-vibrations standsYes
Colissimo - TNT - SoColissimo
2 reviews
Supprime les interférences
Avec le boitier en acrylique je ne passais pas plus d'une journée sans que Volumio plante à cause des interférences.
Depuis l'installation du boitier en aluminium cela fait 7 jours que Volumio fonctionne sans avoir à le rebooter.
A confirmer par d'autres utilisateurs.
This review has been posted for ALLO aluminum case for DigiOne player and Raspberry Pi
Excelent boots.
The little rubber feet have tot be glued. If the design would be a Little different this would not be necessary. Greater feet or...
Not all micro USB connectors Will fit, There is not much space due to the ( Nice) foot of the box.
