DIY 100% Aluminium Chassis 311x220x90mm
DIY Box 100% Aluminium 311x220x90mm
Reference : 9078
75,00 €tax incl.
62,50 € tax excl.
This product is temporarily unavailable.
Shipping from France
Billing in France
Technical support in France
his DIY 100% Aluminum case with cutout display is ideal for integrating an amplifier or other audio editing.
Its robust design ensures an efficient assembly and use with a professional finish.
Dimensions Internal:
  • Working width: 203.5mm
  • Depth: 300mm
  • Working height: 84mm
External Dimensions:
  • Width: 220mm
  • Depth: 311mm
  • Height: 90mm
Box sold to assemble.
Specifications:
  • Solid Brushed Aluminum
  • Façade: 8 mm
  • Rear face: 4mm
  • Display: 113x33mm (118.5x53.5mm inside)
  • Internal Diameter of Potentiometers: 6mm
  • Weight: 2.5kg
  • Supplied with screws, buttons and IEC socket.
MaterialMetal
Internal width203
Internal depth300
Internal height84
Top class chassis full aluminum
This is a very nice designed full aluminum chassis, with a remarkable quality of finishes, both for the solid thick aluminum faceplate and for the anodizing of the rest of the case plates. Also, the shape and finish of the massive ALU knobs (delivered in the package) is outstanding. For the front plate, the cut-out is exactly dimensioned for 'TEK Vomit backlight white dB with calibration module' (but check with the store support for accuracy), as the front plate has the exactly window cut-out for the TEK Vu-meters, but it also has the necessary cut-out milled on the back of the front panel for the shape of the VU-meter plastic box.
The bottom and back plates are not hard, but very easy to drill/mill for the needed holes. In my case, the chassis hosts a led biased Mu-follower line preamplifier based on E88CC.
Highly recommended!
This review has been posted for DIY 100% Aluminium Chassis 311x220x90mm
