Mooi afgewerkt, prijs waard.
Housing 410x100x330mm Black
This Lite Audio A28D box is ideal for designing a DIY audio system such as a power amplifier, preamplifier or DAC. Robust, with a 6mm thick front panel, the case will properly protect all components from impact and dust. This front panel also includes a Power ON/OFF button. The rear face is pre-drilled, allowing to accommodate five stereo RCAs and a power supply base (supplied). The housing is also supplied with four feet.
Pre-drilled bottom for Lite Audio modules.
Product type | Case |
Material | Front panel : Aluminium Other panels : anti-scratch paint |
Color | Front panel : Black Others parts of the case : Black |
Dimensions (L x D x H) | 410 x 330 x 100mm |
Front panel dimensions (L x H) | 430 x 100mm |
Front panel thickness | 6mm |
Weight | 4kg |
Package | 1x Lite Audio A28D case 5x Stereo RCA 1x ON/OFF button and switch 1x Power connector 4x Feet 1x LED |
Color | Black |
Color | Silver |
Material | Aluminium |
Internal width | 410 |
Internal depth | 330 |
Internal height | 100 |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jef B.
Juan N.
sang c.
Anthony F.
