AUNE B1S Portable Headphone Amplifier Discrete Class A
The Aune B1S, a new version of the B1, impressed by its class A design, integrated in a small format case, ideal for mobile use. With a large battery, the B1S will be able to accompany you during your travels.
By buying this product you get 22 loyalty points
12393
229,00 €tax incl.
190,83 € tax excl.
Available
Shipping date: 23-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Aune B1S
Class A Discrete Headphone Amplifier
Aune B1S
The Aune B1 back!
The Aune B1 comes back in an improved version, the Aune B1S. Like its predecessor, it benefits from a Class A design and has been designed to power the most demanding helmets.
Class A in reduced format
Aune achieves the feat of integrating a Class A amplifier into an extremely small format. A design that will allow the amplifier to deliver rich, warm, generous, just and powerful sound to your music.
Aune B1S Class A
Adjustments to all headphones
The B1S has settings on its sides to adjust the amount of current used for amplification or gain adjustment. Thus, the amplifier is able to drive all types of HiFi headphones.
Aune B1S THD+N
An adapted battery
DAPs have developed rapidly in recent years. The B1S is the solution that will allow you to effectively amplify your DAP signal, ensuring an extremely low distortion of 0.0002%.
Un design sublime
The Aune B1S asserts itself with an inspiring design that is both robust and stylish. Black brushed Aluminium, the amplifier also has two windows that reveal its components, the heart of the amplifier.
Amplification typeClass A
Class A25mW / 16R
50mW / 32R
Gain adjustmentYes
Battery4000mAH
Autonomy5h to 10h depending on the selected mode
Battery condition test LEDs-
THD+N0.00015% @ 300Ω
SNR124dB @ 300Ω
Frequency response10Hz to 20kHz (+-0.02dB)
Crosstalk< 110dB @ 300Ω
Output max level6.443Vrms 18.4dBu (10Hz à 20kHz)
Power74mW @ 32Ω, 84mW @ 300Ω et 42mW @ 600Ω
Connectors
Input1x Stereo Line input 3.5mm
Sortie1x Stereo headphone output 3.5mm
Charging1x Mini-USB port
Dimensions125 x 65 x 18mm
Weight230g
Case materialAluminium
Accessories1x Jack 3.5mm cable Male/Male 15cm
1x USB-A Male to Micro USB Male cable 50cm
1x User manual
Schéma Aune B1S
ColorNoir
StructureAluminium
ClassClass A / AB
InputJack 3.5mm
OutputJack 3.5mm
Colissimo - TNT - SoColissimo
The Aune B1S, a new version of the B1, impressed by its class A design, integrated in a small format case, ideal for mobile use. With a large...
