Ibasso D14 BUSHMASTER Headphone Amplifier / USB DAC ES9018K2M 32bit/384kHz DSD
Ibasso D-Zero MKII Headphone Amplifier / USB DAC 2x WM8740 24bit/96kHz
Reference : 10203
249,00 €tax incl.
207,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The iBasso D14 BUSHMASTER is a versatile and compact mobile device with extraordinary Audio capabilities in line with its predecessors and the reputation of the brand.
Both powerful headphone amplifier and high-end USB DAC (connected to a computer as well as an Android or iDevice terminal), it can work in DAC + AMPLI, in stand-alone AMPLI, or as a stand-alone DAC (output function line).
This extremely compact "Combo" is also comfortable in sedentary use connected to a microcomputer rather than roaming.
With the size of a credit card and a low weight, it enters the circle of ultra compact Hi-Fi devices combining the functions of DAC and high-quality amplifier.
The iBasso D14 BUSHMASTER proves to be the ideal companion for any music lover who owns Smartphone or Tablet wishing to enjoy very high resolution audio files.
Features:/ Strong>
  • DAC: ESS Converter Sabrg ES9018K2M
  • Interface USB 2.0 Asynchronous XMOS
  • Supports PCM files up to 32bit 384kHz and DSD256
  • Frequency response: 17Hz - 20kHz to +/- 1dB (DAC), 17Hz - 100kHz to +/- 1dB (Amplifier)
  • Signal Noise Ratio: 115dB (DAC line out), 116dB (Amplifier)
  • THD: 0.0018% at 1kHz / -10dBF (DAC), 0.0012% at 1kHz / Max. (Amp)
  • Output Impedance: 0.1 ohm
  • Output Power: 400mW + 400mW at 32 Ohm
  • Recommended impedance (headphones): 8 to 300 Ohm
  • Gain: +3 / + 9dB (Amp)
  • Lithium-Polymer battery rechargeable via USB (4.2 V)
  • Charging time: 5 h
  • Autonomy: 13 h (Ampl + DAC), 25 h (Amp only)
  • External power supply: 5V DC
  • Chassis Aluminum
  • Black Anodized
  • Dimensions: 60x104x20mm
  • Weight: 150g
  • Comes with a USB cable, interconnect jack cable, rubber feet, two elastic support and an OTG USB cable
  • Compatible with Android (from 4.2), Windows, Mac OS and iDevices with photo kit.
