TOPPING NX1S Headphone amplifier on battery 150mW / 32 Ohm Black
TOPPING NX1S headphone amplifier
Reference : 12153
39,90 €tax incl.
33,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
TOPPING NX1S
Portable Headphone Amplifier
Simple and efficient
The Topping NX1S is the ideal solution that is easy to use and extremely efficient, giving your earphones a whole new dimension. Replacing the famous NX1A it pushes the limits exceeding the characteristics requested for the High Definition files with a bandwidth of 20-100KHZ. Thanks to a shorter track circuit the NX1S is 25% more compact than the old NX1A model.
Revue par Audio Science Review
En somme, le NX1s est un produit inhabituel qui s'illustre par ses performances dans les domaines difficiles (bruit et distorsion) mais pas dans les domaines faciles (réponse en fréquence).
 test par le forum de mesure Audio Science Review
High-quality components
The NX1S uses only quality components, studied to offer you optimal performance. Thus, you find EPCOS capacitors as well as an ALPS potentiometer. The fully revised and corrected circuit now includes operational amplifiers TI OPA1652 and LMH6653 with unit gain.
Autonomy suitable for mobile applications
Separate specific settings
Thanks to the switch on the amplifier, you can precisely adjust the gain for better dynamics, the desired bass level and obtain improved sound.
A volume of type "CLAWS" in a case of aluminum
Designed with CNC numerical control the matte surface in aluminum and its laser engraving offers a modern and elegant design. The design with flap on the sides protects the connector and the potentiometer knob In a pocket or jacket, so the volume can not vary in level inappropriately.
ConnectorsAnalog Input: 1x 3.5mm
Headphone output: 1x 3.5mm
Frequency response20-100kHz +/- 2dB
Max power output150mW (32Ohm, THD + N = 1%)
Signal to noise ratio117dB at 300 Ohms
THD + N Minimum0.003% 32ohms
acceptable helmet impedances16-300Ohms
input sensitivity2.8Vrms low gain 1V high gain
Noiseless than 3μV under 32ohm
Gain0dB / 8.7dB
battery capacity1000 mAh
Mega bassOn / Off
Selecting gainHigh / Low
Dimensions8.4 x 5.5 x 1cm
Housing100% aluminum
Weight78g
Chargevia Micro USB
Accessories1x audio cable
1x USB cable
2x silicone straps
5x velcro
1x user guide
InputJack 3.5mm
OutputJack 3.5mm
3 reviews
merci
livraison rapide
This review has been posted for TOPPING NX1S Headphone amplifier on battery 150mW / 32 Ohm Black
bon produit
Bonjour, je possède le modèle précédant le NX1a. le nouveau modèle a une autonomie moins longue pour une qualite plus riche en détail sur un casque sennheiser HD250 Linear II 300 Homs .je suis satisfait du premier modèle et encore plus satisfait de celui sis
Le Topping un petit ampli pour intras.
Mon smartphone ayant une puissance d'amplification réduite j'ai acquis ce petit ampli et je dois dire qu'il donne un peu plus de volume sur les intras et molette du volume et celui de l'ampli au maximum je peux apprécier ma musique à un niveau plus réaliste cependant il ne faut pas espérer utiliser cet amplificateur de puissance modeste avec un casque dont les membranes à remuer sont plus large et quelle que soit sa sensibilité ou son impédance vous n'obtiendrez aucun résultat avec ce Topping, un ampli plus puissant est donc requis et aussi plus coûteux.
Ce petit ampli très bon marché est donc justifié sur des intras assez sensible de préférence et la qualité sonore est de mon point de vue améliorée par rapport à ce que donne celle du téléphone sortie casque.
