TOPPING NX2S USB DAC Headphone Amplifier on Battery PCM5101A SA9226 32bit / 192Khz Black
TOPPING NX2S USB DAC Headphone Amplifier Black
The DAC and headphone amplifier Topping NX2S will ensure your listening to the headphones a new, rich and detailed restitution. This one integrates high quality components allowing it to support sample rates up to 32bits 192Hz.
Reference : 12279
79,90 €tax incl.
66,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
    Topping NX2S
    DAC USB OTG & portable headphone amplifier
    Topping NX2S DAC USB OTG & Amplificateur Casque Portable
    Simple and efficient
    The Topping NX2S is both easy to use and extremely effective, offering you a whole new dimension in headphone listening. Both DAC and amplifier, it will allow you to enjoy both an accurate digital-to-analog conversion and a considerable power boost for dynamic listening.
    Topping NX2S
    Incredible performances
    The NX2S benefits from Hi-Res Audio certification, the promise of high quality file support and beautiful playback. But the Topping amplifier / DAC goes further by pushing the limits of this certification by ensuring a frequency response between 20Hz and 100kHz. A nomadic amplifier / DAC ideal for your Android or iOS smartphone, thanks to its fine sound reproduction as well as its compactness.
    A TI PCM5101A DAC with quality components
    The NX2S conversion stage is based on a PCM5101A DAC from Texas Instruments perfectly adapted for a powerful mobile device. This chip supports PCM sampling rates up to 32bit 192kHz and reduces noise, EMI interference and jitter (thanks to its PLL).
    The entire design of the NX2S is impeccable, offering high quality components, always with the objective of providing excellent audio quality in a reduced and easily transportable format. Thus, there are operational amplifiers TI OPA1658 and LMH6643 but also a digital input stage based on a SaviAudio Bravo DA9226 chip.
    Topping NX2S DAC TI PCM5101A
    Topping NX2S autonomie
    Autonomy adapted to your nomadic uses
    To accompany you throughout your travels, the NX2S Topping carries a 1000mAh battery. It can be read for 40 hours or 5 hours in DAC mode. Charging the DAC is done directly, in just a few hours, via a dedicated Micro USB port.
    An amp / DAC adapted to all uses
    This OTG amplifier / DAC by its format is particularly suitable for mobile use with an OTG Android or iOS smartphone but will prove equally powerful alongside a computer for example. Because of this versatility, Topping provides a multitude of cables, allowing you to associate the NX2S to each of your devices.
    The NX2S even provides an analog input as a 3.5mm jack to act as a headphone amplifier for non-OTG smartphones.
    Topping NX2S Ampli Casque DAC nomade
    Package
    Dimensions
    DACTI PCM5101A
    Frequency response20Hz - 100kHz +/-2dB
    SNR121dB @ 300Ω
    THD0.0006% @ 32Ω
    Headphone acceptables impedances16-300Ω
    Input sensitivity1.8Vrms
    Noise< 2µV @ 32Ω
    Gain5.6dB
    Battery1000mAh
    Autonomy40h in playback
    5h in DAC mode
    Connectors
    InputsDigital : 1x Micro USB OTG (up to 32bit 192kHz)
    Analog : 1x Stereo Jack 3.5mm
    Output1x Jack 3.5mm
    Dimensions90 x 58 x 9mm
    Housing material100% Aluminium
    Wheight74g
    ChargingVia Micro USB
    Package1x Topping NX2S
    1x male Jack 3.5mm to male Jack 3.5mm cable
    1x male Micro USB to male Micro USB cable
    1x male Lightning to male Micro USB
    1x male USB-A to male Micro USB
    1x male USB-C to male Micro USB
    2x Silicone elastics
    1x Anti-slip pad
    10x Velcro adhesive pads
    OutputJack 3.5mm
    Excellent!
    Excellent dac/ampli casque, super packaging et très bonne qualitée de son, il pilote bien mon casque Senheiser HD 650.
    This review has been posted for TOPPING NX2S USB DAC Headphone Amplifier on Battery PCM5101A SA9226 32bit / 192Khz Black
    The DAC and headphone amplifier Topping NX2S will ensure your listening to the headphones a new, rich and detailed restitution. This one integrates...
