TOPPING NX4S USB DAC battery Headphone Amplifier ES9038Q2M 32bit/768Khz Noir
The NX4S Topping is the ideal solution, both easy to use and extremely effective, to offer your headphones a whole new dimension. It pushes the limits, exceeding the characteristics required for High Definition Hi-Res files with a bandwidth of 20Hz - 100kHz.
Reference : 12549
159,00 €tax incl.
132,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
    Topping NX4DSD
    Topping NX4DSD DAC USB Amplificateur Casque sur Batterie ES9038Q2M 32bit 768kHz Noir
    Simple & Efficient
    The NX4S Topping is the ideal solution, both easy to use and extremely effective, to offer your headphones a whole new dimension. It pushes the limits, exceeding the characteristics required for High Definition Hi-Res files with a bandwidth of 20Hz - 100kHz. This USB OTG 32bit 384kHz OTG 32bit 384kHz DSD512 Native nomadic DAC is thus an ideal client for its thinness and compactness, providing a converter is a high quality headphone amplification for Android and iOS smartphones. (depending on the model and operating system).
    Components of the highest quality
    Das NX4S DSD verfügt über die Referenzen des Marktes in Bezug auf Komponenten, die darauf ausgelegt sind, Ihnen eine optimale, Hi-Res-zertifizierte Leistung zu bieten. Die hochwertige Schaltung beinhaltet eine XMOS U208 USB-Schnittstelle mit drei separaten Clocks, einen ES9038Q2M DAC und die neueste Generation der TI OPA2140 Operationsverstärker. Diese Architektur ermöglicht es, PCm-Abtastraten bis zu 32bit 768kHz und DSD512 bis zu nativen DSD zu unterstützen. Darüber hinaus bietet es einen SNR von 119 dB und einen THD+N von nur 0,0008% im USB-DAC-Modus.
    An autonomy adapted to your mobile uses
    USB DAC battery Headphone Amplifier ES9038Q2M 32bit768Khz BlackThe Topping NX4 DSD includes a large battery allowing it to have an extended battery life for long listening sessions, whether in mobile mode with a smartphone or in sedentary mode using the DAC function. Thus, its autonomy is 28 hours in playback mode in headphone amplifier mode and 7h30 in USB DAC mode + headphone amplifier. LED indicators indicate when it is necessary to charge the NX4 DSD.
    Topping NX4DSD DAC USB Amplificateur Casque sur Batterie ES9038Q2M 32bit 768kHz NoirTopping NX4DSD DAC USB Amplificateur Casque sur Batterie ES9038Q2M 32bit 768kHz Noir
    Topping NX4 DSD Review by Audio Science Review
    The Topping NX4 DSD is a superb portable DAC and headphone offering at super attractive pricing. The DSD NX4 has impressed me greatly. It would be my choice for a portable headphone+DAC or a stand-alone desktop DAC for that matter. "
    Test du Topping NX4 DSD par Audio Science Review
    Product typeDAC and Headphone Amplifier
    Inputs1x Jack 3.5mm
    1x Micro USB OTG
    Output1x Jack 3.5mm
    Frequency response20Hz - 100kHz +/-2dB
    Max output power293mW @ 32Ω, 114mW @ 300Ω
    SNR119dB @ 1kHz
    THD0.0008% @ 1kHz
    Acceptable headphone impedances16-300Ω
    Input sensitivity1.8Vrms
    Noise< 2µV @ 32Ω
    Gain5.6dB
    Battery capacity2400mAh (temps de chargement 4h)
    Supported sampling ratesPCM up to 32bit 768kHz
    DSD up to DSD512 natif
    Crosstalk-96dB @ -1kHz
    Switchable gain0dB / 8.8dB
    Dimensions11 x 6.8 x 1.4cm
    Case materialAluminium
    Weight148g
    LoadVia Micro USB
    Accessories1x Audio Cable 3.5m
    1x Micro USB Cable
    1x USB-C Cable
    1x USB Charger
    2x Silicon strips
    5x Velcros
    1x User guide
    InputJack 3.5mm
    OutputJack 3.5mm
    vrais dac 32 bit 768k DSD512 natif abordable
    je l'utilise depuis quelques jour, connecté à 2 PC windows 10.
    la qualité est excellente, riche, j'utilise foobar qui est gratuits,
    avec 3 plugins. merci aux développeurs pour leur travaille remarquable.
    Au niveau fabrication il semble de bonne qualité avec des composants bien choisis.
    attention tout de même au 2 connecteurs micro USB qui sont très fragiles, c'est le problème avec ce type. je n'utilise pas les câbles USB fournis pour le moment.
    j'ai 2 casque DT 770 PRO un de 250 ohm et l'autre de 80 ohm,
    les 2 fonctionnent à merveille.
    je recommande ce produit si vous êtes soigneux.
    This review has been posted for TOPPING NX4S USB DAC battery Headphone Amplifier ES9038Q2M 32bit/768Khz Noir
    The NX4S Topping is the ideal solution, both easy to use and extremely effective, to offer your headphones a whole new dimension. It pushes the...
