LITTLE DOT MKIV MK4 SE Tubes Headphone Amplifier / Preamplifier
Little Dot MKIV MK4 SE Amplificateur casque à tubes
The Little Dot MKIV is the flagship headset amplifier of the brand. It uses a Single Ended Push-Pull amplifier circuit class A based on MC8100 / 6AK5 tubes. These tubes are surrounded by quality components such as a potentiometer ALPS RK-27, capacitors Nichicon, Rubycon, WIMA, ERO ...
By buying this product you get 64 loyalty points
Reference : 5439
649,00 €tax incl.
540,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
This amplifier can driver headphones from 32 to 600ohm without forcing thanks to its output capable of 45V peak-to-peak.
RCA outputs allow it to be used as a preamp by taking advantage of the Class A
In addition to this, this amp includes an externally accessible gain adjustment to best match the impedance of your headphones.
It is also possible to change the input tubes by EF92, CV131, WE403A / B, GE5654, M8100, CV4010, EF95, 6JI or compatible (Requires the addition of a jumper)
The versionMK4 SEis a special edition that features improved connectivity such as a Jack Neutrik socket, branded RCA sockets, and first choice components at key locations on the circuit.
The versionSEalso uses different tubes, M8100 / CV4010 input, and 6H30PI with golden pins as power tubes.
Specifications:
  • SEPP (Single Ended Push Pull) OTL in Class-A
  • Frequency response: 10Hz - 100kHz (-1dB)
  • THD + N: 0.1% (100mW @ 300 ohm)
  • Output Power
    • 500mW @ 300/600 ohm
    • 300mW @ 120 ohm
    • 100mW @ 32 ohm
  • Power Consumption: 30W
  • Adjustable gain: 3, 4, 5 or 10x
  • Recommended load: 32 to 600ohm
  • Input impedance: 50k ohm
  • Preamp section:
    • Output impedance: 600 ohm
    • Gain: 3 to 10x (linked to amp gain)
    • Voltage: 10V RMS
    • Input and output tubes active on output preamp
  • Input Tubes:
    • 2x MULLARD M8100 / CV4010 (MKIV SE)
  • Power Tubes:
    • 2x SOVTEK 6H30PI (MKIV SE)
  • Aluminum chassis
  • Dimensions: 320x220x143mm
  • Weight: 3.5kg
  • Warranty 1 year
  • Comes with a 6.3mm to 3.5mm jack adapter
OutputJack 6.35mm
ClassTube amp
3 reviews
I LOVE THIS AMP
I have also the LD1+ but MKIV SE is just so much better at everything.
The amount of bass,midbass and midrange is surprising great pairing with my Grado RS1x razor sharp neutron star dense bass pure audio bliss. There is plenty of power that I will probably never need this much but good to have it just in case.
There is slight microphonics but proper placement away from electromagnetic fields from other electronics helps.
Those tubes improved after 60 hour so much better separation of layers, better details everything.
Delivery and sent was fast and reliable highly recommended audiophonics is GREAT.
I will be back in the future for sure!
This review has been posted for LITTLE DOT MKIV MK4 SE Tubes Headphone Amplifier / Preamplifier
Just perfect!
It replaced a broken Schiit lyr 2 and I'm amazed how much better the Little Dot is.
le Little Dot MK4 SE est superbe !!! finition exemplaire , le son est superbement chaud et détaillé, je l'ai depuis 3 jours et suis impatient de finir le rodage pour pouvoir profiter pleinement de sa restitution sonore qui je sais ,va s'améliorer avec le temps.......
je l'utilise aussi comme préampli un régal , je suis vraiment comblé par mon achat .
seule ombre au tableau je ne sors plus de chez moi , et reste scotché devant ma chaine , enchainant les disques !!!!!!
The Little Dot MKIV is the flagship headset amplifier of the brand. It uses a Single Ended Push-Pull amplifier circuit class A based on MC8100 /...
