Passive Preamplifier converter RCA to XLR / XLR to RCA Silver
Class-A Preamplifier Volume control & Source selector
This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from unbalanced RCA to balanced XLR. The two buttons on the front panel will be able to allow all cases of RCA to XLR, XLR, to RCA, RCA to RCA or even XLR to XLR.
Reference : 12360
54,90 €tax incl.
45,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
Passive preamplifier
Préamplificateur Passif Convertisseur RCA vers XLR / XLR vers RCA Argent
This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from unbalanced RCA to balanced XLR. The two buttons on the front panel will be able to allow all cases of RCA to XLR, XLR, to RCA, RCA to RCA or even XLR to XLR. The robust appearance and the aluminum housing make this a real toolbox for passive stereo volume control and single-ended balanced-to-unbalanced converters at a reasonable price.
Product typePassive preamplifier
RCA / XLR Converter
Inputs1x Stereo RCA
1x Stereo XLR
Outputs1x Stereo RCA
1x Stereo XLR
Volume controlPotentiometer 10k
Input / Output switchXLR and RCA
Dimensions149 x 121 x 43mm
Weight520g
ColorSilver
InputXLR
ColorSilver
MaterialAluminium
Channel2 (Stereo)
3 reviews
Very good for its price
This little box works great when used from balanced in to balanced out. When going from unbalanced in to balanced out, I experienced some quality loss, but only on certain loud numbers / passages. I guess it is not expected for a passive pre in this price range to be able to balance an unbalanced source. Unbalanced in to unbalanced out worked great too. The only case I didn’t try was balanced in to unbalanced out. As a curious person I opened my unit and saw that the potentiometer has printed C20K, I guess it is actually a 20K potentiometer? Anyway, it sounds great and the price is great
This review has been posted for Passive Preamplifier converter RCA to XLR / XLR to RCA Silver
contrôleur passif pratique et très bien fabriqué
J'avais besoin de ce type d'appareil pour régler mes enceintes de monitoring. Ce petit contrôleur offre un signal parfait musicalement, aucune interférence, bref un appareil d'un prix plus que raisonnable qui correspond exactement à ce que je cherchais et qui rempli son rôle impeccablement.
Préamplificateur & Contrôleur de Volume
Produit top qualité, fournit un message musical exceptionnel, si associé à du très bons matériels Transport et DAC. Bravo à Audiophonic de produire de tels matériels de qualité sans comparaison avec le prix pourtant très modéré.
Merci
This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from...
