LQSC Class AB Stereo Module Amplifier TDA7377 2x30W 4 Ohm
This low-cost yet highly efficient Class AB amplifier module is based on a TDA7377 chip allowing it to develop up to 2x30W under 4Ω. The quality components integrated in this module, such as Nichicon capacitors for filtering or gold-plated contacts, ensure a beautiful sound reproduction.
1.0 / 5
Reference : 13801
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Amplifier module
Module Amplificateur Stéréo Class AB TDA7377 2x30W 4Ω
This low-cost yet highly efficient Class AB amplifier module is based on a TDA7377 chip allowing it to develop up to 2x30W under 4Ω. The quality components integrated in this module, such as Nichicon capacitors for filtering or gold-plated contacts, ensure a beautiful sound reproduction. At the input of this module is a 3.5mm jack connector as well as a 2.54mm 3 pin XH connector. At the output, the board simply offers screw terminals to connect to your speakers. The module also includes a rotary knob for volume control.
Product typeAmplifier module
ChannelsStereo (2)
Amplification chipTDA7377
Amplification typeClass AB
Power2x30W @ 4Ω
Inputs1x Stereo Jack 3.5mm
1x 3 pins XH 2.54mm connector
OutputsSpeaker screw terminals
Supply voltage9-18V DC
ProtectionsShort circuit
Over heat
Overcurrent
PCB dimensions58.7 x 55mm
Total dimensions90.6 x 55 x 26.7mm
Fixation holes spacing48 x 25.5mm
Package1x Amplifier module
1x 3 pins XH 2.54mm
InputXH 2.54mm
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTDA7377
Power (W)30.0
Soudure sèches - Potentiomètre grippé
J'ai reçu le produit avec des soudure défaillantes sur les condensateurs. Le potentiomètre était également non fluide, avec des points durs. A éviter.
This review has been posted for LQSC Class AB Stereo Module Amplifier TDA7377 2x30W 4 Ohm
This low-cost yet highly efficient Class AB amplifier module is based on a TDA7377 chip allowing it to develop up to 2x30W under 4Ω. The quality...
