MA-TD06 TDA8954SMPS Class D 2x170W / 340 W Stereo Class D Amplifier Module
TDA8954SMPS Module Amplificateur Class D 2X170W stéréo 340 W mono
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 22-03-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
This module can achieve a power density of 1.5W / gram and an overall volume of only 20 inches has a power density of 18W.
It is the most compact powered amplifier in its class with output power is 2x170W under 4 Ohms or 2x90W under 8 Ohms.
The output power in BTL mode is 340W on the impedance of 8ohms speakers.
All these powers are measured at <1% THD.
The supply voltage is 115V AC or 230V AC, 50 or 60Hz.
The input signal may be symmetrical or asymmetrical.
The amplifier has overvoltage, overcurrent and short-circuit protection.
The gain of the amplifier is 30dB in single-ended mode and 36dB in BTL mode.
The power transistors and rectifying diodes of the power supply section do not require a heat sink for operation with a music signal due to the high efficiency of the power supply.
Characteristics :
  • Dimensions: 150x56x45mm
  • Power: 340 W under 8 ohms (mono) or 2x170W at 4 Ohms or 2x90W at 8 Ohms.
  • "Ploc" anti-ignition system
  • Auxiliary output +/- 15V 250mA
  • It is necessary to put it in contact with the casing to improve the dissipationnot(see diagram below)
  • Weight: 240g
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
