HYPEX UCD400HG HxR Mono Power Amplifier Module 400W
Module amplificateur Hypex UCD400HG HxR 400W
The UCD amplifiers in the HG range are high-end versions of the UCD180ST and UCD400ST amplifiers. They are available in 2 versions: UCD180HG and UCD400HG. They're perfect for audiophile use.
Reference : 3084
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 19-03-2024.
Shipping from France
Billing in France
Technical support in France
The models in stock have the modification for use with the SMPS400/67 power supply.
Hypex UCD400HG
Amplifier Module HG HxR 400W
The HG series UCD amplifiers are high-end versions of the UCD180ST and UCD400ST amplifiers. They are available in 2 versions: UCD180HG and UCD400HG. They are perfect for audiophile use.
The HG modules are class D digital amplifier modules equipped with uncompromising components.
Many improvements
This model incorporates many improvements, allowing it to achieve ever higher audio performance. Here is a list of these improvements:
  • Audiophile version of the modulator (chopper)
  • Use of high quality resistors and capacitors for the chopper and around the input buffer
  • Audiophile voltage decoupling capacitors
  • Improved voltage regulator for the input buffer (HxR only)
  • Audiophile input decoupling capacitors
  • Even lower distortion rate
  • Improved temperature stability
  • Quality Potentiometers: Sealed Bourns 3362 P
  • Better power FETS for faster chopping and lower THD
  • Input buffer: AOP LM4562
Technical data
Flat response curve independent of load impedance-
Output impedanceVery low: 20 milliOhm
Very low distortion, independent of frequency-
Ultra-low-noise circuit-
Operates with balanced power supply-
On-Off function without "Ploc-
Balanced input-
Protected against overvoltage and short circuits-
Power supply range+/- 45V-67V (Typ. +/- 57V)
Possible applicationsMonitor speakers for recording studios.
Audiophile amplifiers for professionals and amateurs.
Public Address systems
Home cinema systems Active speakers
InputNC
OutputPCB Connector
Channel1 (Mono)
Amplifier chipN/A
Power (W)400.0
Excellent produit
J'ai utilisé 2 modules UCD400HG pour remplacer les 2 modules identiques de mon Micromega AS400 qui donnaient des signes de faiblesse après 12 ans d'utilisation.
Sans surprise je retrouve la sonorité originelle de mon AS400, c.a.d un son neutre, détaillé, transparent et dynamique. Ces modules permettent d'avoir de vraies basses sur des enceintes difficiles à driver et gourmandes en courant, telles mes Martin Logan Theos dont l'impédance peut tomber à 0,7 ohm.
Avec une bonne alim, un bon préampli et un bon refroidissement (c'est de la classe D mais 400 W cela chauffe !), ces modules peuvent donner beaucoup pour un prix très raisonnable. Seuls petits bémols : la diode bleue d'un des modules s'éteint lorsque l'ampli est chaud alors que le module semble parfaitement fonctionner, et puis je m'aperçois que j'ai payé chaque modules 6 € plus cher que leur prix actuel.
This review has been posted for HYPEX UCD400HG HxR Mono Power Amplifier Module 400W
The UCD amplifiers in the HG range are high-end versions of the UCD180ST and UCD400ST amplifiers. They are available in 2 versions: UCD180HG and...
