Amplifier Module Mono class D TPA3118D2 Bluetooth 30W / 8 Ohm
Reference : 14223
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Mono Amplifier Class D TPA3118D2
This extremely compact amplifier bluetooth module receives dematerialized digital input stream and outputs a single amplified output signal.
It operates a class D amplifier TPA3118D2 chip mounted in bridge, allowing it to deliver considerable power 30W while retaining very advantageous dimensions and without requiring sink. It also benefits from superior performance to 90% making it an amplification solution tailored for compact projects.
The module finally shows its ease of integration: the power connector and the amplified audio output connector are already materialized on the PCB via connectors like Phoenix. The supply circuit for its part offers a wide range of options with compatibility with voltages from 12 to 24V for an intensity of 3A.
Dimensions
The module has extremely small dimensions.
distances
The PCB has only one hole for mounting. The latter is located on the connectors side to stabilize the module where the tension would occur if the cables were accidentally pulled.
TypeModule amplification
InputsBluetooth
OutputsScrew terminals
Power12 to 24V DC
ClassD
Amplification ChipTPA3118D2
Power30W / 8Ω
Channelsx1 (mono)
Dimensions31 x 50 x 17mm
OutputScrew terminals
Channel1 (Mono)
Amplifier chipTPA3118
Power (W)30.0
6 reviews
Powerful enough and without hiss and hum
I tried other TPA 3116/3118 amps, that all suffered from an audible hiss. This one is really quiet.
Bluetooth connection is automatic and fast.
I have been able to power it from 8 volt to 20 volt without issue
This review has been posted for Amplifier Module Mono class D TPA3118D2 Bluetooth 30W / 8 Ohm
Parfait pour radio anciennes
Utilisé sur trois radios à tubes pour les transformer en caisson bluetooth avec un très bon résultat: très petit, on peut le placer dans le meuble sans éliminer le cadre avec le circuit originel. Puissant et avec un bon tmbre.
Petit mais...
Installer dans une radio TSF des années 50 et branché sur un HP Fostex large bande de 16, le niveau sonore et la qualité des timbres sont étonnent
Petit ampli, oui mais bleufent !
Parfait
J'ai utilisé cet ampli mono pour rénover une vielle radio.
Parfait très petit (attention chauffe un peu) mais une belle puissance développée pour la taille. A voir si il vieillit bien.
La qualité du son est très très correcte.
Conforme à mes attentes
Parfait pour redonner vie à un ancien poste des radio des années 50.
Récepteur bluetooth performant.
Vraiment tout petit, attention aux serrages sur les borniers.
