SURE AA-AB32274 Stereo 2x1200W Class D Audio Amplifier Board
SURE Stereo 2x1200W Class D Audio Amplifier Board
By buying this product you get 25 loyalty points
255,00 €tax incl.
212,50 € tax excl.
Shipping date: 22-03-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
- Class D / 2x1200W
Amplificateur Sure 2x1200W
This Class D Sure amplifier has the particularity of offering a high power output. It is therefore suitable for Hifi but also for specific uses such as a cinema room, the amplification of musical instruments or even systems for recording studios.
High quality sound
The HPA consists of a series of 12 high-power amplifiers powered by a single power supply. All of the amplifiers are controlled by a Class-T modulator, providing both warm and powerful sound. This amplifier includes features such as signal loops and high-quality components to provide exceptional sound performanceonal
Adjustable input sensitivity
The input sensitivity of the amplifier series can be adjusted quite broadly. This allows the system to adapt to various types of sources. It can accept as input a maximum power of 10Vrms and impedances of 1.5 to 16 Ohms.
Continuous full power
With high efficiency up to 93% and very low power consumption, HPA delivers high power efficiency. Its design has also been designed to effectively dissipate residual heat with a fan controlled by a probe. This allows the amplifier chips to operate stably by delivering from 500W to 2000W.
Tests that ensure high durability
The series of amplifiers is integrated in accordance with the principle of durability. Thus, they are tested both with a dummy load resistor of 1kW and a 2550W air conditioning system in parallel. These tests ensure that each amplifier can withstand the harshest uses, and therefore your audio uses.
Signal detection
The module has a signal detection system, allowing the system to automatically change channels, in order to improve the user experience and simplify the daily use of the product.
Many protections
The amplifiers are equipped with four protection systems to avoid material damage: overvoltage, overcurrent, excessive temperatures, anti-inversion high voltage.
High-quality components
Sure selects soigneusits suppliers in order to equip its products with the best possible components in terms of performance and durability.
  • Output power:
    • 2000W under 2 Ohms 96V THD + N 10%
    • 1500W under 2 Ohms 96V THD + N 1%
  • Power Supply Wide: DC48V - 120V
  • Adjustable impedance: 1.5 Ohms to 16 Ohms
  • Automatic Signal Detection
  • Optimized thermal control
  • High voltage reverse protection
  • Capacitive and resistive loads supported
  • Adjustable input sensitivity
  • Dimensions: 15.24 x 11.43cm
schema branchement ampli Sure 2x1200W
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
