FX-AUDIO M-DIY TDA8950 Class D Amplifier Board 2x170W 300W BTL 4 Ohm
TDA8950 class D Amplifier Module 2x150W 4 Ohm
The DIY TDA8950 amplifier module from FX-Audio allows the design of a high-performance amplification system capable of delivering a power of 2x170W at 4 Ohm or 300W in BTL.
Reference : 12143
15,90 €tax incl.
13,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
Amplifier board Class D 2x170W 300W BTL
FX-Audio M-DIY TDA8950 Module amplificateur Class D 2x150W 2x170W 4 Ohm
The DIY TDA8950 amplifier module from FX-Audio allows the design of a high-performance amplification system capable of delivering a power of 2x170W at 4 Ohm or 300W in BTL. The card benefits from a compact volume thanks to the latest generation of Philips NXP Class D chip. Equipped with a large heatsink, it can be easily integrated into all quality amplifier projects such as home theater and hifi power amplifiers. It is also ideal for designing multi-amplified active or passive systems. The module offers 2 single-ended inputs.
Surprisingly musical and dynamic, this module is a relevant choice for the enlightened amateur at a controlled cost.
Product typeAmplifier type
Amplication chipTDA8950E
Power2x170W 4 Ohm, 300W BTL
Power supplyAC +/-24V (Min 16V / Max 28V) (transformer sold separately)
Integrated potentiometerVolume control
Dimensions100 x 100mm
Weight200g
Wiring diagram
FX-Audio M-DIY TDA8950 Schéma de câblage
1AC +/-24V Power Supply Input
2Speakers Output
3Single-Ended Input
4Single-Ended Input
BTL Wiring Diagram
Schéma câblage BTL FX-Audio M-DIY TDA8950
InputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTDA8950
Power (W)300.0
Power (W)170.0
Cablage des entrées asymetriques en stereo me parrait incomplet .´
Bonjour ,
Suite à l'achat de 4 modules , 2 montés en BTL fonctionnement OK , mais pour les deux autres en stereo et entrée asymetrique , les modules restent muets .
Les entrées sont differentielles , donc adaptées au montage symetrique , mais en mode asymetrique une des entrées doit etre reliée à la masse , operation qui ne peut etre faite que par cablage donc ......... peut etre l'origine de ce PB .
AUDIOPHONICS pourra j'espère apporter sont conseil .
cordialement
This review has been posted for FX-AUDIO M-DIY TDA8950 Class D Amplifier Board 2x170W 300W BTL 4 Ohm
The DIY TDA8950 amplifier module from FX-Audio allows the design of a high-performance amplification system capable of delivering a power of 2x170W...
