TINYSINE TSA3118B SMA Amplifier Module TPA3116D2 Bluetooth aptX TWS 2x50W
TINYSINE TSA3118 Amplifier Module TSA3118B Bluetooth aptX TWS SMA 2x50W
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks to its Class D architecture. The module also integrates a Bluetooth AudioB Plus receiver from the brand, supporting the aptX protocol which allows faster and more stable signal transmission.
Reference : 14142
40,90 €tax incl.
34,08 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
TinySine TSA3118B SMA
TinySine 3118 Module Amplificateur TSA3118B Bluetooth aptX TWS SMA 2x50W
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good performance thanks to its Class D architecture. The module also integrates a Bluetooth AudioB Plus receiver from the brand, supporting the aptX and aptX Low Latency protocols that allow faster and more stable signal transmission. The TSA3118 can be used to accompany passive speakers with an impedance of 4 or 8 Ohm.
The module can also be used in TWS mode. The latter allows you to wirelessly pair several of these amplification modules and therefore enjoy a multi-channel system. The 3-pin audio output connector can also be used to connect a Subwoofer amplifier module. The BVC port allows it to connect a volume control module such as the TinySine TSA1000 or TinySine TSA1020. Finally, this version of the module integrates an SMA connector on the Bluetooth receiver to connect the supplied antenna and thus increase the Bluetooth transmission distance.
The amplifier automatically detects the AUX and line inputs as well as Bluetooth, the latter having a higher priority. When the Bluetooth source is disconnected or paused, the amplifier automatically switches to the AUX / Line input.
The combination of the TSA3118 and TSA1000 allows you to control the volume level via the BVC port, whether for RCA or Bluetooth input.
Several TSA3118 modules can be connected together to create a multi-channel amplification system. The audio output connector can also be connected to an amplifier module for subwoofer.
2 modules operating in TWS mode.
It is necessary to remove the jumper activating the Auxiliary input of the slave module before pairing to TWS.
xxx
  • S1 : Press 3s to enter pairing mode. Press 6s to reset the pairing information.
  • S1 + S2 : Press 1s to enable TWS slave mode.
  • S1 + S3 : Press 1s to enable TWS master mode.
  • S2 + S3 : Press 1s to disable TWS connection.
Product typeAmplifier module TPA3116D2
Amplification ClassD
InputsBluetooth
1x Line input on PH2.0 3 pins connector
OutputsSpeaker terminals
1x Stereo RCA
1x Line output on PH2.0 3 pins connector
Other connectors1x BVC port for control panel on PH2.0 5 pins connector
Bluetooth version4.2
Supported Bluetooth codecsaptX, aptX Low Latency
AAC
SBC
TWS support
Codecs Bluetooth supportésaptX, aptX Low Latency
AAC
SBC
ProtectionsOver voltage, Under voltage
Overload
Thermal protection
Measurements
ParameterConditionMin.Typ.Max.
Supply voltage-10V DC21V DC24V DC
Max current100W @ 4Ω-5.29A-
Efficiency50W @ 4Ω87%-92%
Minimum load impedance-3.2Ω--
Switching frequencySD Floating-394kHz-
Gain-24dB25dB26dB
Input sensitivity (RMS)@ 4Ω, 50W, 1kHz-808mV-
Input impedance--22kΩ-
Output power@ 4Ω THD+N 1%-36W-
@ 4Ω THD+N 10%-50W-
Frequency response@ +/-3dB, 4Ω20Hz-20kHz
THD@ 4Ω, 1W, 1kHz-0.0299%-
@ 4Ω, 10W, 1kHz-0.073%-
Dimensions9 x 103 x 20mm
Fixation holes spacing86.5 x 60mm
Package1x TinySine TSA3118B board
1x Bluetooth antenna
InputPH 2.0mm
OutputPH 2.0mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)50.0
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good efficiency thanks...
