TinySine 3118 Module Amplificateur TSA3118B Bluetooth aptX TWS SMA 2x50W
This amplifier module from TinySine is based on a TPA3116D2 amplifier chip that can deliver up to 2x50W while offering very good performance thanks to its Class D architecture. The module also integrates a Bluetooth AudioB Plus receiver from the brand, supporting the aptX and aptX Low Latency protocols that allow faster and more stable signal transmission. The TSA3118 can be used to accompany passive speakers with an impedance of 4 or 8 Ohm.
The module can also be used in TWS mode. The latter allows you to wirelessly pair several of these amplification modules and therefore enjoy a multi-channel system. The 3-pin audio output connector can also be used to connect a Subwoofer amplifier module. The BVC port allows it to connect a volume control module such as the TinySine TSA1000 or TinySine TSA1020. Finally, this version of the module integrates an SMA connector on the Bluetooth receiver to connect the supplied antenna and thus increase the Bluetooth transmission distance.
The amplifier automatically detects the AUX and line inputs as well as Bluetooth, the latter having a higher priority. When the Bluetooth source is disconnected or paused, the amplifier automatically switches to the AUX / Line input.
The combination of the TSA3118 and TSA1000 allows you to control the volume level via the BVC port, whether for RCA or Bluetooth input.
Several TSA3118 modules can be connected together to create a multi-channel amplification system. The audio output connector can also be connected to an amplifier module for subwoofer.
2 modules operating in TWS mode.
It is necessary to remove the jumper activating the Auxiliary input of the slave module before pairing to TWS.
Product type | Amplifier module TPA3116D2 |
Amplification Class | D |
Inputs | Bluetooth 1x Line input on PH2.0 3 pins connector |
Outputs | Speaker terminals 1x Stereo RCA 1x Line output on PH2.0 3 pins connector |
Other connectors | 1x BVC port for control panel on PH2.0 5 pins connector |
Bluetooth version | 4.2 |
Supported Bluetooth codecs | aptX, aptX Low Latency AAC SBC |
TWS support | |
Codecs Bluetooth supportés | aptX, aptX Low Latency AAC SBC |
Protections | Over voltage, Under voltage Overload Thermal protection |
Measurements | ||||
Parameter | Condition | Min. | Typ. | Max. |
Supply voltage | - | 10V DC | 21V DC | 24V DC |
Max current | 100W @ 4Ω | - | 5.29A | - |
Efficiency | 50W @ 4Ω | 87% | - | 92% |
Minimum load impedance | - | 3.2Ω | - | - |
Switching frequency | SD Floating | - | 394kHz | - |
Gain | - | 24dB | 25dB | 26dB |
Input sensitivity (RMS) | @ 4Ω, 50W, 1kHz | - | 808mV | - |
Input impedance | - | - | 22kΩ | - |
Output power | @ 4Ω THD+N 1% | - | 36W | - |
@ 4Ω THD+N 10% | - | 50W | - | |
Frequency response | @ +/-3dB, 4Ω | 20Hz | - | 20kHz |
THD | @ 4Ω, 1W, 1kHz | - | 0.0299% | - |
@ 4Ω, 10W, 1kHz | - | 0.073% | - |
Dimensions | 9 x 103 x 20mm |
Fixation holes spacing | 86.5 x 60mm |
Package | 1x TinySine TSA3118B board 1x Bluetooth antenna |
Input | Bluetooth |
Input | PH 2.0mm |
Output | RCA |
Output | PH 2.0mm |
Output | Speaker terminal |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3116D2 |
Power (W) | 50.0 |
