TINYSINE TSA8800B Amplifier Module
The TinySine TSA8800B amplifier module combines the functions of a 2.1-channel Class D amplifier, DAC / DSP and integrates an AudioB I2S Bluetooth receiver supporting the high-resolution aptX and aptX HD codecs. It can deliver up to 2x90W of power and features a 200W subwoofer output. To achieve this, it uses TPA3321 amplifier chips. DAC / DSP signal processing is performed by an ADAU1701 chip, enabling tone adjustment for each channel. In addition to Bluetooth reception, a stereo RCA input is also available. This module also supports TWS, enabling several modules to be connected together.
Reference : 19431
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 26-05-2026.
TINYSINE TSA8800B Class D 2.1 Amplifier Module TPA3221 DAC DSP ADAU1701 Bluetooth 5.1 aptX HD 2x90W + 200W 4 ohm
The ADAU1701 DSP chip features a preloaded program for adjusting gain, bass, midrange and treble in the Sigma Studio DSP program/interface. A debug port is available for Sigma Studio. To access advanced features, users can program the TSA8802D module via TinySine's USBi programmer. The advanced functions available include equalization, crossover, bass enhancement, multiband dynamic processing, delay compensation and more. The TSA8802D amplifier module is powered by 12V-30V DC and is capable of driving passive speakers with an impedance of 2Ω, 4Ω or 8Ω.
Overview of the TinySine TSA8800B amplifier module
TinySine TSA8800B : Description diagram
1External LED port
212-30V DC power supply input
3RCA input
42x100W speaker output
5200W subwoofer output
6DSP in / out
7External buttons port
8Potentiometers port
9Mute port
10DSP progrmmation port
11Audio output port
Port descriptions
DSP input/output port
Three input/output pins are available for the ADAU1701 DSP chip: MP6, MP7, MP0. It is possible to develop a DSP program to meet different requirements. For the default firmware, if you connect these pins to GND, the TSA8800B will emit a 1kHz sine wave.
Port for external buttons
There are three buttons on the module which can control volume, play/pause, etc... External buttons can also be connected using the dedicated port.
Pinout:
  • P/P  play / pause button
  • VOL +: volume up and fast forward
  • VOL -: volume down and fast rewind
  • 3.3V
TinySine TSA8800B : Pinout du port pour boutons externes
Potentiometer port
External potentiometers (5K-20K) can be connected to the module to control master volume, treble, midrange and bass. It is necessary to update the DSP software beforehand. A specially adapted potentiometer kit is sold separately.
Pinout:
  1. ADC0: main volume
  2. ADC1 : bass volume
  3. ADC2 : mid volume
  4. ADC3 : treble volume
DSP programming port
The TSA8800B's DSP detects both Bluetooth and RCA signals, but the default program gives higher priority to Bluetooth. If the Bluetooth signal is detected, the TSA8800B will output a Bluetooth audio source, otherwise the RCA output will take over. It's also possible to develop a DSP program to suit different needs, then load the new DSP program using the USBi JTAG Sigma DSP programmer (sold separately).
Connection modes and buttons
TinySine TSA8800B: Classic connection diagram
TinySine TSA8800B: Diagram of a TWS connection between two modules
TinySine TSA8800B : Control buttons diagram
  • S1: press and hold for 3s to activate pairing mode. Long press for 6s to reset pairing information
  • S1 + S2: Long press for 1s to activate TWS slave mode
  • S1 + S3: long press for 1s to activate TWS master mode
  • S2 + S3: long press for 1s to deactivate TWS mode
Product typeAmplifier module
Amplification typeClass D
Channels2.1
Output power (stereo output)2x 112W @ 3Ω, 10% THD+N
2x 105W @ 4Ω, 10% THD+N
2x 100W @ 3Ω, 1% THD+N
2x 88W @ 4Ω, 1% THD+N
Output power (subwoofer output)208W @ 2Ω, 10% THD+N
InputsBluetooth 5.1
1x Stereo RCA
OutputsSpeaker outputs on screw terminals
Subwoofer output on screw terminal
Bluetooth version5.1
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD
TWS supportYes
I2S Sampling rates48kHz
Amplification chipsTPA3221
DSP chipADAU1701
THD+N0.02% @ 1W
SNR108dB @ A-wt, gain=18dB
Dynamic range109dB @ A-wt, gain=18dB
Minimum load impedance3-4Ω
GainMin : 18dB
Typ : 24dB
Max : 34dB
Efficiency90% @ 100W, 4Ω
Input impedance48kΩ @ 18dB
24kΩ @ 24dB
12kΩ @ 30dB
7.7kΩ @ 34dB
ProtectionsOver voltage
Under voltage
Over current
Over heat
Supply voltage10-30V DC (power supply sold separately)
Dimensions145 x 100 x 34mm
Package1x TinySine TSA8800B module
1x Bluetooth antenna
OutputScrew terminals
OutputSubwoofer
Channel2 (Stereo)
Amplifier chipTPA3321
Power (W)90.0
The TinySine TSA8800B amplifier module combines the functions of a 2.1-channel Class D amplifier, DAC / DSP and integrates an AudioB I2S Bluetooth...
