TPA3116D2 Amplifier Module 2.1 Class D Bluetooth 4.0 2x50W + 100W with Filter Volume and Tone Control
TPS3116D2 Amplifier Module Class D Bluetooth 4.0 2x50W + 100W with Filters and Volume Control
This Class D amplifier module based on two TPA3116 chips will allow you to manufacture a complete, simple and efficient device. This one has Bluetooth for a more practical use as well as settings of tones, in order to be able to adapt the restitution to your system. It is a 2.1 module, capable of delivering 50W in stereo but also 100W additional for the use of a subwoofer.
4.0 / 5
Reference : 13067
44,90 €tax incl.
37,42 € tax excl.
Shipping from France
Billing in France
Technical support in France
Amplifier TPS3116D2
Amplifier board 2.1 Class D Bluetooth 4.0 2x50W + 100W with Filter Volume Tone Control
Amplificateur TPS3116D2 Hypex UCD400HG Module Amplificateur HG HxR 400W
TPS3116D2 TPA3116
Dual TPA3116D2 chip for a 2.1 amplifier
The TPS3116D2 amplifier module therefore includes a pair of TPA3116 amplification chips. These allow you to deliver 2x50W for your satellite speakers, but also 100W more, dedicated to powering a subwoofer for a boost in low frequencies. In addition, the architecture of the amplifier, in Class D, makes it possible to benefit from a very good output. As a result, it loses less energy, which gives it a good power reserve.
Control your music from your sofa
This module benefits from a very practical connectivity, since in addition to its 3.5mm stereo jack input, it offers Bluetooth 4.0. With this feature, it becomes possible to stream your music from your sofa, via a smartphone or any other device with Bluetooth connectivity (transmission). With the 4.0 standard, it ensures a much better transmission speed and stability, thus allowing a better sound reproduction. To change source from 3.5mm Jack input to Bluetooth, simply press and hold the Global Volume (Master) button for 3 seconds.
TPS3116D2 Bluetooth
TPS3116D2 Contrôle tonalités
Adapt the restitution of your system according to your desires
The TPS3116D2 has a series of 5 rotary knobs. These will allow you to adjust the bass, treble, overall volume (master), satellite volume, subwoofer volume and finally a low pass filter. These numerous settings will allow you to adapt the playback of your system according to your listening style or music genres.
Diagram
tps3116d2-amplifier-class-d-bt-inpage2.j
Amplification chip2x TPA3116
Output power2x 50W + 100W
Impedance4 Ohm for the satellite speakers
3-4 Ohm for the subwoofer
SNR100dB
InputsStereo Jack 3.5mm
Bluetooth
3 pins connector
Output6 screws terminal
Power supply12-24V DC Jack DC 5.5x2.1mm (Not included)
Max current3A
Dimensions10 x 2.3 x 3.94mm
tps3116d2-amplifier-class-d-bt-inpage3.j
InputJack 3.5mm
OutputSpeaker terminal
Channel2.1
Amplifier chipTPA3116D2
Power (W)50.0
4 reviews
SAV décevant
Produit fonctionnel malgré un gros ploc désagréable dans les haut parleurs lors de la mise sous tension de l'ampli, pour ma part l'ampli présente un dysfonctionnement au bout du 4ème mois d'utilisation modéré, ce qui rend impossible son utilisation.
Le SAV propose une réparation en renvoyant l'ampli à l'usine mais si ils ne trouvent aucun problème lors de leurs tests, une facture de 30 euros sera à payé. Solution décevante sachant que cet ampli est vendu plus de 30 euros moins chère chez les concurrents.
This review has been posted for TPA3116D2 Amplifier Module 2.1 Class D Bluetooth 4.0 2x50W + 100W with Filter Volume and Tone Control
expédition super rapide, et l'emballage est sur secur. Continuer comme ça !
Ampli TPA3116D2
Très bon produit, correspond à ce que j'attendais, très bon site sérieux.
très bon
j'ai été surpris de la qualité du son je le recommande à tout le monde
This Class D amplifier module based on two TPA3116 chips will allow you to manufacture a complete, simple and efficient device. This one has...
