WONDOM AA-JA32473 JAB3-30 Class D Stereo Amplifier Module with DSP 2x30W
4.5 / 5
Reference : 12163
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
WONDOM AA-JA32473 JAB 3-30
Class D Amplifier module with DSP Stereo 2x30W
WONDOM AA-JA32473 JAB 3-30 Module Amplificateur Class D avec DSP Stereo 2x30W
High Quality Audio Performances
The Wondom Class D JAB3-30 amplifier module provides 2x30W of power. With its integrated DSP it is ready to be integrated into your DIY projects. The JAB3-30 delivers 2x30W of power while delivering high quality sound. The JAB amplifier series incorporates Parallel Bridge Tied Load (PBTL) technology in which two outputs can be connected together on one channel, resulting in higher power and efficiency.
JAB1 & JAB2 Compatibility
The JAB1 and JAB2 offer a stereo solution for Bluetooth speakers. The JAB3s, in addition to offering a headphone amplifier, include a DSP. This means that when a JAB3 works with a JAB1/2, you get a complete 4.0 (BTL), 2.1 and 0.2 (PBTL) audio system with control interface and signal processing.
Integrated DSP
Thanks to an integrated serial debug port, you can reprogram the integrated DSP in your JAB3 amplifier in order to modify / add new functions. There are two ways to do so (one is really powerful while the other is quick and simple)
SigmaStudio
SigmaStudio is certainly the most complete and powerful solution for ADAU1701 DSP Chip programming (and the most technical as well). This solution lets you set up your JAB3 with many digital processing tools such as equalizers, crossovers (frequencies redirection) specific treatement for low frequencies, multiband dynamics...etc. SigmaStudio is a very powerful tool that can also set specific signal processing algorithms for each channel.
The SigmaStudio method uses a programmation module to flash the DSP internal memory (integrated to JAB3). Once it is done, the JAB module runs the DSP algorithms independent when powered (does not need the programmation module to stay plugged).
This solution is also suited for non-HIFI applications (sound acquisition / synth) that need to use both Σ-Δ ADC and the four integrated Σ-Δ ADC, while enjoying a dynamic range of 98.5dB. Each ADC has a THD+N of -83dB and each DAC has a THD+N of -90dB.
Getting started with SigmaStudio
You will find on this page a guide to discover SigmaStudio and a walkthrough to connect the programming module as an interface between your JAB3 and your computer.
Tutoriel Sigma Studio
MIUMAX
The app MIUMAX (available on Android) is by far the simplest solution and allow you to set up your JAB3's DSP in a few minutes. This method covers the functions of volume / gain / filters / delay / phase / 10-bands equalization, which is already impressive for a DSP integrated to an amplifier of this size / power.
MIUMAX uses the programming module ICP3 as a remote control which uses your smartphone (or any bluetooth device running on android or IOS) as an interface for DSP configuration. MIUMAX's configuration menu is really easy to understand for beginners.
It is also a very pratical tool for real-time test while being able to move and experience the whole listenning room.
Product typeAmplifier with DSP module
ChannelStereo (2)
Power2x30W
Integrated DSPADAU1707
Signal detection-
2.1/0.1 Mode-
PBTL Mode (Parallel Bridge-Tied Load)
Integrated headphone amplifier
ControlsPossibility to add a control module (sold separately)
CompatibilityJAB1
JAB2
OutputsSpeaker terminal (PBTL)
1x Jack 3.5mm
Power supply19V
Measurements
ParameterConditionsMin.Typ.Max.
Number of channel--2-
Output current limit--7.5A-
Output under PLIMIT voltage-6.75V7.9V8.75V
Minimum load impedanceOutput filter: L=10uH, C=680nF3.2Ω8Ω-
Efficiency30W @ 8Ω-91%-
Nominal power requirement--30W-
Operating voltage-11V19V24V
Switching frequencySD Floating @ 24V-406kHz-
Consumption1/4 of max output power @ 8Ω, 24V-0.75A-
1/8 of max output power @ 8Ω, 24V-0.46A-
Battery under voltage protection--10.3V-
Minimum gain@ 8Ω, 1kHz26dB26dB32dB
Input sensitivity30W @ 8Ω, 1kHz-0.4V-
SNR4W @ 8Ω, THD+N = 1%-85db-
THD+N1W @ 8Ω, 1kHz-0.1%-
10W @ 8Ω, 1kHz-0.12%-
Input impedance--10kΩ-
Slew rate@ 8Ω, input filter bypassed--10V/ms
Output noise levelA-Weighting,input connected to GND-65uV-
Bandwidth @ ±3dB@8Ω250Hz-18kHz
Crosstalk separationf=1kHz, Gain = 20dB--60dB-
DC Offset--1.5mV15mV
Max input level--26dBu-
Dimensions91 x 69mm
Package1x Wondom JAB3-50 module
1x Molex/JST XHP 4 pins power cable (for AA-JA11113 module)
1x Extension cable (for AA-JA11112 module)
1x HP cable
InputNC
OutputMolex
Channel2 (Stereo)
Amplifier chipN/A
Power (W)30.0
2 reviews
Attnetion bande passante 250-20 000Hz !
Je n'ai pas été assez attentif à l'achat mais au moment de me motiver à l'installer dans mon enceinte portable, en lisant la doc je me suis aperçu que cet ampli ne donnera rien en dessous de 250Hz ! ça mériterais d'être plus clairement écris à mon avis.
Faire pour alimenter tweeter / medium donc.
Aussi, je n'ai toujours pas compris comment brancher le câble jack3.5 vers 4pin dans l'entrée audio de la carte. le câble fourni à cet effet n'est pas utilisable en l'état ou c'est moi qui n'a pas compris...
This review has been posted for WONDOM AA-JA32473 JAB3-30 Class D Stereo Amplifier Module with DSP 2x30W
nice board
