WONDOM JAB2 AA-JA32171 V2 Amplifier Board Class D Bluetooth 5.0 DSP 2x50W 4Ω
WONDOM JAB2 V2 Amplifier Board Class D Bluetooth 5.0 DSP 2x50W 4Ω
Wondom's JAB2 V2 is an integrated Class D amplifier module, integrating a DSP and a Bluetooth reception function (aptX HD). This version of the JAB2 V2 is capable of delivering a power of 2x50W.
Reference : 14994
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Wondom JAB2 V2
Wondom JAB2 V2 Module Amplificateur Class D Bluetooth 5.0 DSP 2x50W 4Ω
Wondom's JAB2 V2 is an integrated Class D amplifier module, integrating a DSP and a Bluetooth reception function (aptX HD). This version of the JAB2 V2 is capable of delivering a power of 2x50W. Its DSP chip allows it, after connection to the Wondom ICP3 (or higher) and to a PC, to access the modification of parameters such as volume level, gain, frequency or equalization.
In addition to its speaker output, the JAB2 V2 offers an additional mixed signal output, allowing the audio stream to be sent to another amplifier board to design a 2.1 or 4.0 audio system. It is also possible to configure it as a subwoofer signal by frequency adjustment in via the PC interface.
On the power supply side, the JAB2 V2 can be powered conventionally in 10.8-24VDC or using a battery to improve its portability.
Bluetooth 5.0
Benefiting from Bluetooth 5.0 connectivity, the JAB2 V2 supports the aptX, aptX HD, aptX LL, SBC and AAC protocols and has a high reception sensitivity with RF power up to 9dB and -90dBm. The module integrates an antenna to enhance reception quality and distance. An external antenna port is also present.
Line input
In addition to its Bluetooth connectivity, the JAB2 V2 has a 3.5mm jack line input. The signals from these two input modes are mixed before being transmitted to the amplification circuit.
DSP & PC Interface
After connection with an ICP3 module (sold separately), it is possible to access the PC configuration interface. This software developed by Sure will allow you to adjust the gain level, high and low pass filters, noise suppression, bass control, frequency offset and many other effects.
Battery operation (optional)
The JAB2 V2 can be battery powered. It uses an MPPT charging circuit. To power the module in this way, it will be necessary to use the additional AA-JA11113 lithium battery module (sold separately).
Product typeAmplifier module
InputsBluetooth 5.0
1x Jack 3.5mm line input
OutputsSpeaker output Molex
1x Mixed audio output PH 2.0mm
Amplification typeClass D
Power output2x 50W @ 4Ω, 21V
ChannelsStereo (2)
PBTL Mode support
Supported Bluetooth codecSBC, AAC, aptX, aptX HD, aptX LL
RF Reception Sensitivity9dBm and -90dBm
Integrated DSP
Gain28dB to 32dB
THD0.06% @ 4Ω, 10W, 1kHz
Noise output level134.5µV @ A-Weighting, input connected to GND
SNR97.3dB @ 10W, 4Ω, THD+N=1%
Power supply11-24V DC
Dimensions91.44 x 68.58mm
Package1x Wondom JAB2 V2
1x Power cable
Speaker cables
InputJack 3.5mm
OutputPH 2.0mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipN/A
Power (W)50.0
très bon et installation très propre avec le kit supplémentaire
En ajoutant le kit de cablage et le support aluminium, on obtient une solution très propre, avec bouton de volume très proprement cablé pour être efficace (le volume agi après le mix des entrées bluetooth et line-in et le processing DSP et avant l'étage d'amplification). Dans ce cas la le mute automatique sur silence fonctionne très bien alors que si on n'installe pas le potentiomètre du kit et qu'on baisse trop le niveau des entrée le mute automatique se déclenche trop souvent dans les silences de la musique.
This review has been posted for WONDOM JAB2 AA-JA32171 V2 Amplifier Board Class D Bluetooth 5.0 DSP 2x50W 4Ω
Wondom's JAB2 V2 is an integrated Class D amplifier module, integrating a DSP and a Bluetooth reception function (aptX HD). This version of...
