VIABLUE T6S F-Plug satellite Ø9.5mm (Pair)
Viablue T6S Connecteur F satellite (la paire) Ø9.5mm
Reference : 3143
15,99 €tax incl.
13,33 € tax excl.
Shipping from France
Billing in France
Technical support in France
Viablue T6S F-PLUG Satellite F type connector
T6SF ViaBlue connector
Superior class of connectors with minimal resistance and great holding. The aluminum body with gold plated contacts 24K ensures high strength and excellent durability while remaining lightweight with exceptional conductivity.
body mounting ViaBlue T6S-F
Modular connector
The end of T6S-F connector is removable. One Viablue connector body will be able to accomodate all Viablue's interchangeable connectors. This represents a considerable advantage from the standpoint of space usage and parts availability when adding a new device to your system or replacing an existing unit.
Except XLR connectors, connectors and body Viablue T6S share the same internal fixation system. Every body can receive the appropriate connector as needed without causing mechanical compatibility problem.
Tips available separately
Connector ferrules T6SF
All T6s series connectors are supplied with 2 diameter reducers. These reducers allow the connectors to better adapt to the cable diameter. The small gearbox has an external diameter of 7.5 mm and an internal diameter of 4.5 mm. Thus cables with a diameter of 3 mm to 4.5 mm can be mounted securely.
The large one has an outside diameter of 9.5 mm and an inside diameter of 7.5 mm. Thus cables with a diameter of 5 mm to 7.5 mm can be mounted securely. Without reducers, cables with a diameter of 7.5 mm to 9.5 mm can be installed.
Product typeSatelite connector
ReferenceT6S
Plating24k
ConductorOFC Copper
Compatible cable diametersWith small gear: 3 / 4.5mm
With great reducer: 5 / 7.5mm
Gearless: 7.5 / 9.5 mm
Connexion typeTo solder
Package
T6S-F Connectorx2
4.5mm Diameter reducerx1
7.5mm Diameter reducerx1
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
Max panel thickness (mm)N/A
Impedance (Ω)NC
