AUDIO-GD C-2 EDITION 2019 Class A Preamplifier / Amplifier Headphone analogue
AUDIO-GD C-2 11TH Class A Preamplifier / Amplifier Headphone analogue
This Audio-GD C-2 Edition 2019 is the asymmetrical version of the excellent NFB-1AMP, itself based on the design of MASTER 9. Thus, it integrates many technical evolutions and will be able to " the most demanding.
By buying this product you get 57 loyalty points
Reference : 10036
579,00 €tax incl.
482,50 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
Audio-GD C-2
2019 Edition
Audio-GD C-2
This is the 2019 version of the Audio-GD C-2. This version benefits from an update of its MCU firmware allowing the device to have more functions and to control them more easily.
An affordable 2-in-1 ...
The Audio-GD C-2 is the asymmetrical version of the NFB-1AMP also based on the design of the famous MASTER 9, this new amplifier headphone / preamplifier resumes all the recent evolutions of the brand. Able to deliver a rare power, it will be comfortable to "drive" the most demanding helmets.
Cthe firm's product has been scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision.
High-fidelity connectivity, especially provided
It has 5 analog inputs: 4x RCA Stereo and 1x ACSS Stereo, along with 2 analog outputs also: RCA and ACSS, stereo every 2.
Andof course do not forget the 2 headphone outputs on the front panel: XLR 4 PIN / Jack 6.35mm, compatible with the most demanding headphones on the market.
Back Audio-GD C-2
Signature Audio-GD on all floors
ACSS / XLR / RCA / Class A / 100% Discreet
This C-2 has a 100% discreet design and is backed by a high-power Class A power supply. The RCA connectors and 6.35mm jack sockets are manufactured by the famous brand of audio connectors: Neutrik.
The latter thanks to its extensive connectivity, which is particularly surprising for a product of this range, is compatible with all analog sources and power amplifiers on the market.
Audio-GD C-2
ACSS
ACSS
Audio-GD has its own technology signature called ACSS for "Audio-GD Current System Signal". Thanks to the expertise and know-how of the firm, this technology offers a less colored, more detailed sound, and an unparalleled neutrality.
Chaque engineer technician of the brand is, in addition to being experienced, a passionate of HiFi and Audio like you and us.
Remote Control Metal
This C-2 11th comes with its metal remote control, brushed aluminum finish. You will find 2 buttons to switch between your sources, as well as 3 buttons to adjust the volume: Plus / Minus / Mute. All the sobriety and class of Audio-GD stand out from this remote, as it is purified and functional.
Télécommande Audio-GD C-2
SNR125dB
Gain+ 19dB
Frequency Response20Hz - 20kHz (0.1dB) / 3Hz - 135kHz (-3dB)
Headphone Output Power (Class A)25Ω 3000mW / 40Ω 2000mW / 100Ω 900mW / 300Ω 300mW / 600Ω 150mW
Headphone output power (Max)25Ω 9900mW / 40Ω 8000mW / 100Ω 3500mW / 300Ω 1200mW / 600Ω 600mW
Preamp output power10V (RCA) / 2.4mA (ACSS)
Impedance ofexit
Input impedance47KΩ (RCA) / 94KΩ (XLR) / <10Ω (ACSS)
crosstalk> 120dB
Channel imbalance<0.05dB
Various
Consumption30W
WeightAbout 5kg
Housing material100% Anodized aluminum
Dimensions240 x 360 x 80mm
AccessoriesPower / Remote Control Cable
InputACSS
OutputACSS
OutputJack 6.35mm
Polyvalent, puissant et très droit
Pour le moment j'utilise ce C2 avec le DAC audio GD R2R2, relié en ACSS. Ecoute majoritaire au casque HE-560 (très requérant en courant). Rodage effectué.
Ce qui frappe en premier lieu c'est le silence, le rapport signal/bruit est fantastique. Chaque instrument est extrêmement bien placé, la dynamique est excellente et mon orthoplanar bouge comme il se doit.
Côté usage courant, le bouton "out" permet de switcher à volonté entre la sortie casque et les sortie lignes, le nombre d'entrées lignes est confortable.
Le bouton gain permet de s'adapter à votre casque (impédance et sensibilité).
Reste le débat symétrique/asymétrique. Le C2 est asymétrique, totalement adapté aux casques classique en terminaison single ended, comme le dit le concepteur : "Different to the NFB-1AMP:
The C-2 is a single ended headamp and preamp (+/- 30V DC high voltage power supply ), The NFB-1AMP is balance headamp and preamp (+/-15V DC power supply ). So They had same output power specs can drive most headphone as well.
If customer like to keep your headphone with single ended connector (6.3MM), choice the C-2 get better performance than the NFB-1AMP".
This review has been posted for AUDIO-GD C-2 EDITION 2019 Class A Preamplifier / Amplifier Headphone analogue
This Audio-GD C-2 Edition 2019 is the asymmetrical version of the excellent NFB-1AMP, itself based on the design of MASTER 9. Thus, it integrates...
