MiniDSP U-DIO8 Digital interface 8 channels S/PDIF BNC 192KHz USB 7.1
MiniDSP U-DIO8 Interface digitale
The UDIO-8 is an ideal solution for audio performance-oriented projects demanding many high quality chanels.
S/PDIF Version
By buying this product you get 48 loyalty points
Reference : 12747
489,00 €tax incl.
407,50 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
miniDSP UDIO-8
USB digital interface 8 asynchronous channels 192kHz S / PDIF BNC
digital interface UDIO8
The UDIO-8 is an ideal solution for audio performance-oriented projects.
With up to 8 input channels individually capable of converting the sampling frequency received, it can receive and treat separately the frequencies of 32 to 216kHz, and matches the output with the selected internal frequency used on the driver software (ASIO 44.1-192kHz)
 This digital interface and will set up a high-resolution multichannel setup such as a home theater computer controlled, complex live sound mixing environment or / mastering surround up to 7.1.
Compact device
UDIO-8 dimensions 16.1 x 10.8 x 3.1 cm
The digital interface U-DIO8 manages to keep not less than 8 channels in an extremely compact size (161 x 108 mm). This feat is made possible by the use of connectivity TASCAM DB25 together all the inputs and outputs in a single port while preserving audio quality.
DB25 connectors TASCAM
XLR cable adapter - SPDIF IN (4) and SPDIF Out (4)
Connection to DB25 port is done through an adapter cable DB25 - 4x S / PDIF IN - 4x S / PDIF OUT. This cable is provided with U-DIO8 interface.
A comfortable length 1.5m allow easy and clean installation point of view of the cable-management.
Effective audio design
driver UDIO8
According to the concept of USB digital stream in which exceeds miniDSP the UDIO-8 uses high-quality audio components including a module 16 XMOS hearts for rapid processing of complex multichannel data.
Inputs and outputs are encoded into 24 bits (int) for each track in order to enjoy a highly developed sound depth for stereo streams so that the files 8-channel complex.
The device is automatically detected and integrated into Mac platforms and will require a driver under Windows and Linux. The software interface offers several options to refine the connection and behavior of the digital interface. This will vary the width of the buffer in order to match the host machine performance with the UDIO-8, set the behavior of the device in terms of energy consumption.
The host machine may also individually affect the volume of each channel mono or stereo processing. If required, all channels can be individually defined 0dB (no attenuation).
USB interfaceXMOS 16 core
USBB USB Audio Class 2
digital inputs4x SPDIF (8 channel) to DB-25 connector (Tascam) converting asynchronous sampling (32-192kHz)
digital outputs4x SPDIF (8 channel) to DB-25 connector (Tascam) sampling conversion controlled by the computer
Resolution and sample rate24bit @ 44.1 / 48 / 88.2 / 96 / 176.4 / 192kHz
Chip conversionSRC4382
Dynamic128dB
THD + N-125dB
Operating systemWindows / Linux / Mac / iPad Camera Kit
FoodDC 5V 500mA 2.1mm center positiveSupplied with plug EU / UK / US / AU
ConnectorsdB25 to BNC 1.5m providedUSB A to USB B 1.5m provided
Dimensions31 x 161 x 108 mm
Weight500g
InputDB25
OutputDB25
Max sampling rate192kHz
Interface chipXMOS
The UDIO-8 is an ideal solution for audio performance-oriented projects demanding many high quality chanels. S/PDIF Version
