FX-AUDIO PW-6 2 IN 1 OUT / 1 IN 2 OUT Speaker/Amplifier Audio Selector Switch Black
DYNAVOX AMP-S Speaker Selector Switch for Speaker / Amplifier Black New
This remote-controlled controller allows you to output two pairs of speakers from an amplifier with only one terminal block output for one pair of speakers.
2.0 / 5
12462
64,90 €tax incl.
54,08 € tax excl.
Accessories
This loudspeaker switch box allows you to double the loudspeaker outputs of a stereo amplifier.
This allows two pairs of stereo speakers to be connected to a single amplifier.
The switch from one to the other is very fast thanks to the single button on the front panel or the remote control provided.
The FX-AUDIO PW6 can also be used in reverse connection. You can connect two amps and go out on a single pair of speakers.
Features:
  • Aluminium front panel 4mm
  • Up to 200W / channel
  • Bare cable, banana and fork compatible terminals
  • Remote control: Button 1 means that the input is connected to output A / Button 2 means that the input is connected to output B / The other buttons are not used at the moment
  • Dimensions: 145 x 210 x 75 mm
  • Colour: black
MaterialAluminium
ColorNoir
StructureAluminium
Colissimo - TNT - SoColissimo
Not bad, but improvable (and with big project mistake!)
The selector comes with a good package, the chassis is strong and heavy and the front switches have a good feeling. The display is very simple, the same for the little led indicators, but they works with no problems.
The female banana connectors on the back are ok, not big and strong but they accept the whole male banana. There are 2 big problems: first, the electronic board inside is good, with good traces, but the little red cables tha connects banana plugs to PCB are way too thin!! Second, the bigger problem: when you switch on the second output, the + and - connectors are inverted! So, if you don't test it with a multimeter, you reverse the polarity of the speakers. This is not acceptable. It's not a big problem when you know about it, but it shouldn't be this way. I was thinking about send back the items, but it's not worth it. I'll redo the cabling inside the switches (I've purchased 2 of these).
This review has been posted for FX-AUDIO PW-6 2 IN 1 OUT / 1 IN 2 OUT Speaker/Amplifier Audio Selector Switch Black
This remote-controlled controller allows you to output two pairs of speakers from an amplifier with only one terminal block output for one pair of...
