SHANLING CD-S100 (21) CD Player DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512 Black
SHANLING CD-S00 (21) CD Player DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512 Black
The Shanling CD-S100 (21) is a high quality, high performance and versatile CD player. The core of the system is based on a dual-core Junzheng X2000 processor using XBurst2 architecture, ensuring high power for data processing.
By buying this product you get 54 loyalty points
Reference : 15957
549,00 €tax incl.
457,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The new CD-S100 (23) is now available.
Shanling CD-S100 (21) Lecteur CD DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512
The Shanling CD-S100 (21) is a high quality, high performance and versatile CD player. The core of the system is based on a dual-core Junzheng X2000 processor using XBurst2 architecture, ensuring high power for data processing. The digital-to-analog conversion stage uses an AKM AK4493 chip, efficiently decoding the audio stream for accurate sound reproduction. The CD playback is done by a Philips CD80 servo system and a Sanyo HD850 playback head.
The CD-S100 (21) is also equipped with a Bluetooth 5.0 reception function thanks to the integration of an AP6256AC chip. This one thus allows a wireless audio transmission, from a smartphone for example, and is compatible with the LDAC high quality Bluetooth codec.
There is also an input USB-A port for reading files from a storage device, or a USB-B input, capable of reading high resolution streams up to PCM 32bit 768kHz and DSD512.
For its outputs, the CD-S100 (21) provides an analog output on stereo RCA, as well as two digital outputs, in optical and coaxial formats.
Finally, the front panel of the device features a nice round LCD display with a resolution of 320*290px, capable of displaying information about the current playback as well as the album covers.
Eddict Player App
If the Shanling CD-S100 (21) can be controlled in the traditional way thanks to the remote control supplied with the device, it can also be controlled using the free mobile application Edict Player. This application allows you to browse your music library and also to directly control the playback of your music.
Product typeCD Player
InputsCD
Bluetooth 5.0
1x USB-B
1x USB-A Host
Outputs1x Stereo RCA
1x Optical Toslink
1x Coaxial
CPUJunzheng X2000
DAC ChipAKM AK4493
OPAOPA2134
USB InterfaceJunzheng X2000
ScreenAMLCD 320*290px
Control modeRemote control
App
Supported sampling ratesPCM up to 32bit 768kHz
DSD512
Supported file formatsDSD, DXD, APE, FLAC, ALAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, MP3, M4A, AC30PUS, TAK, CUE
Output level2V
Frequency response20Hz-20kHZ ±1dB
SNR110dB
Distortion< 0.001%
DNR100dB
Dimensions430 x 355 x 79mm
Weight≈ 5.3kg
Package1x CD-S100 (21) Black
1x Power cable
1x Remote control
Excellent lecteur
Acheté il y a 5 mois, correspond parfaitement à mon besoin pour l'utilisation principalement en lecteur CD et connexion bluetooth.
Je n'utilise pas l'appli Eddict Player qui plante systématiquement sur mon android, mais elle n'est pas vraiment utile.
Vraiment très satisfait d'avoir ce maillon dans ma chaine hifi.
This review has been posted for SHANLING CD-S100 (21) CD Player DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512 Black
The Shanling CD-S100 (21) is a high quality, high performance and versatile CD player. The core of the system is based on a dual-core Junzheng...
