By buying this product you get 22 loyalty points
HIFIMAN Deva Pro Bluemini headphones feature an ultra-thin planar magnetic driver based on NsD (‘Neo Supernano Diaphragm’) technology. Thanks to this advanced design, it delivers detailed, accurate sound across the entire audible spectrum. Its 18Ω impedance and 94.5dB sensitivity guarantee excellent compatibility with a wide range of audio sources.
Lightweight and comfortable, it provides a pleasant listening experience even for long sessions. A detachable cable with TRS jack to 3.5mm jack connectors is included. Whether for sedentary or nomadic use, the HIFIMAN Deva Pro is the perfect everyday ally.
This model is accompanied by the R2R Bluemini DAC, enabling wireless Bluetooth operation with SBC, AAC, aptX, aptX HD and LDAC codecs. Whether you're using it on the move or at home, it offers a listening experience without compromising on sound quality.
The HIFIMAN Deva Pro Bluemini headphones come with a Bluetooth R2R DAC for wireless use. It comprises a Qualcomm QCC5124 receiver chip and the brand's proprietary R2R Himalaya DAC. It supports high-resolution Bluetooth codecs: SBC, AAC, aptX, aptX-HD and LDAC. It has USB-C charging port for up to 6-7 hours of autonomy, and simply inserts into the headphones' left earpiece for quick and easy use.
The planar magnetic diaphragm in the HIFIMAN Deva Pro Bluemini headphones features NsD (“Neo Supernano Diaphragm”) technology. This means it's 80% thinner than on the brand's previous designs, for greatly improved transient response, better dynamics and a detailed sound image across its entire frequency range.
The arrangement of the magnets in the HIFIMAN Deva Pro Bluemini headphones limits their impact on sound reproduction. In fact, the magnets are arranged so as to be acoustically transparent to sound waves, enabling clear rendering while reducing the level of distortion.
Extremely lightweight, HIFIMAN Deva Pro Bluemini headphones are comfortable to wear for long listening sessions. The earcups are wide enough to completely cover the listener's ears, for excellent passive isolation. Moreover, their memory foam adapts perfectly to every morphology.
HIFIMAN Deva Pro Bluemini headphones feature 3.5mm jack connectors. A 2x jack 3.5mm TRS to jack 3.5mm termination cable is supplied. However, if you prefer a single cable, this can be achieved by connecting a 3.5mm TRRS jack to the left earcup of the headphones.
Please note that Deva Pro Bluemini is not compatible with 3.5mm TS jacks.
Product type | Headphone |
Heaphone type | Open-Back |
Headphone format | Circumaural |
Driver | Planar magnetic (NsD - Neo supernano Diaphragm) |
Impedance | 18 ohm |
Sensitivity | 93.5dB |
Frequency response | 20Hz-20kHz |
Headphone connectors | 2x jack 3.5mm TRS or 1x jack 3.5mm TRRS |
Removable cable | |
Cable terminaison | Jack 3.5mm |
Bluemini R2R Bluetooth DAC specifications | |
Bluetooth chip | QCC5124 |
DAC | HIFIMAN HIMALAYA |
SNR | 114dB |
Supported Bluetooth Codecs | SBC, AAC, aptX, aptX HD, LDAC |
Battery autonomy | 6-7h |
Charging port | USB-C |
Weight | 25g |
Weight (headphones) | 360g |
Color | Silver |
Package | 1x HIFIMAN Deva Pro headphones 1x Bluetooth R2R DAC Bluemini 1x Detachable cable 2x jack 3.5mm TRS to termination jack 3.5mm |
Color | Silver |
Impedance (Ω) | 18 |
Efficiency / Sensitivity (dB) | 93.5 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 20000 |
Wireless | Yes |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | Jack 3.5mm |
