MONACOR SP-38 / 300NEO Professionnal Speaker Driver Woofer Neodynium 300W 8 Ohm 101dB Ø38cm
Monacor SP-38/300NEO
This large diameter loudspeaker weighs only 2.5kg at a depth of 162mm and has a power handling of 300W RMS at a resonance frequency of 38Hz. It is ideal for the design of lightweight, portable and high-performance stage loudspeakers.
Reference : 1950
189,00 €tax incl.
157,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
-MONACOR SP-38/300 NEO-
This mid-range subwoofer has a rigid, lightweight chassis with a neodymium magnet. This type of magnet has a high magnetic power in relation to its diameter. The Blue Conponent IMG STAGELINE NEO range therefore allows the design or replacement of high-performance loudspeakers with high power handling for public address loudspeakers intended to be often transported without sacrificing the quality of audio reproduction
Technical caracteristics
SPÉCIFICATIONS
Type de haut parleurHigh-power sound pro loudspeakers with light chassis
PowerRMS : 300 W
MAX : 600 W
Impedance
Sensibility101dB @ 1W/1m
Frequency response36Hz - 300Hz
Diameter Coil63mm
DC Coil Resistance (Re)5.4Ω
Coil Inductance (Le)0.75mH
Resonance Frequency (Fs)36Hz
Mecanical Q (Qms)4.13
Elactrical Q (Qes)0.48
Total Q (Qts)0.43
Mouvement mass Air (Mms)71g
Compliance (Cms)0.28 mm/N
Emissive surface (SD)880cm²
Force factor (BL)13.5Tm
Volume of air mass equivalent to mobile crew compliance  (Vas)265L
Maximum linear excursion (Xmax)3.5mm
MaterialPapier cartonné renforcé
Suspension MaterialPetit plis imprégné
Magnet typeNeodynium
Total diameter315mm
Total depth135mm
Magnet DiameterØ140mm
Weight2.5Kg
ColorBlue
Speaker Power (W RMS)300.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)380.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)101.0
Max Linear Excursion (Xmax) (mm)3.5
Lowest frequency (Hz)N/A
Highest frequency (Hz)4000
This large diameter loudspeaker weighs only 2.5kg at a depth of 162mm and has a power handling of 300W RMS at a resonance frequency of 38Hz. It is...
