Monacor SP-46A / 500BS
Monacor SP-46A/500BS
By buying this product you get 38 loyalty points
Reference : 1953
383,70 €tax incl.
319,75 € tax excl.
The new Blue Components from IMG Stage Line: subwoofers with a particularly low low frequency for high efficiency, double spider mechanically very stable: professional bass for extreme low pressure
Professional Subwoofer, 2000 WMAX, 8 Ω
With double centering and settings for powerful bass even in medium cabinetry. Yield above average. The long stroke construction allows a mechanical transposition of extreme power, a subwoofer for truly deep sounds. Suitable for use in professional installations, in disco and on stage.
blank.gifImpedance (Z) blank.gif8 Ω
blank.gifResonance frequency (fs) blank.gif36 Hz
blank.gifMaximum bandwidth blank.giff3-1800 Hz
blank.gifFreq. cut. (Fmax). blank.gif750 Hz
blank.gifMaximum power blank.gif2000 WMAX
blank.gifNominal power (P) blank.gif500 WRMS
blank.gifPressure sound. (1W / 1m) blank.gif98 dB
blank.gifCompliance susp. (Cms) blank.gif0.13 mm / N
blank.gifMovable mass (Mms) blank.gif141 g
blank.gifMechanical resistance (Rms) blank.gif6.9 kg / s
blank.gifMechanical overvoltage. (Qms) blank.gif4.75
blank.gifElectrical overvoltage (Qes) blank.gif0.54
blank.gifFact. total overvoltage (Qts) blank.gif 0.48
blank.gifVolume equ. (VAS) blank.gif250 l
blank.gifDC resistance. (Re) blank.gif6 Ω
blank.gifInductance coil. (The) blank.gif1.65 mH
blank.gifCoil diameter blank.gif100 mm
blank.gifCoil support blank.gifKapton
blank.gifHeight of winding blank.gif20 mm
blank.gifHeight gap blank.gif8 mm
blank.gifLinear Excursion (X MAX)blank.gif± 6 mm
blank.gifTransmitting surface (Sd) blank.gif1163 cm2
blank.gifFlight. air displaced (Vd) blank.gif698 cm3
blank.gifForce factor (BxL) blank.gif17.49 Tm
blank.gifRef. (No) blank.gif2.25%
blank.gifMagnet diameter blank.gif238 mm
blank.gifMagnet weight blank.gif93.4 oz.
blank.gifcutting blank.gifØ 420 mm
blank.gifMounting depth blank.gif205 mm
blank.gifdimensions blank.gifØ 470mm
blank.gifWeight blank.gif11.1kg
blank.gifclosed blank.gif120 l
blank.gif bass reflex blank.gif > 150 l
Colissimo - TNT - SoColissimo
