Compression Monacor MRD-120 1 "
Compression Monacor MRD-120 1"
Reference : 1516
85,00 €tax incl.
70,83 € tax excl.
Motor with horn, 100 W MAX, 8 Ω
With standard 35 mm (1 3/8 ") threads, good linearity of the frequency band and high sound pressure for low distortion: a motor suitable for all types of professional applications, combined with a bass-midrange speaker 38 cm (15 ") or in multi-channel systems. The acoustic values ​​mentioned result from the combination of this loudspeaker with the MRH-120. Replacement mobile reel available as optional MRD-120 / VC.
blank.gifImpedance (Z) blank.gif8 Ω
blank.gifResonance frequency (fs) blank.gif1300 Hz
blank.gifMaximum bandwidth blank.giffx-17500 Hz
blank.gifCrowds. cutoff (fmax.) (12dB / oct.) blank.gif3000 Hz
blank.gifMaximum power blank.gif100 WMAX
blank.gifNominal power (P) blank.gif50 WRMS
blank.gifPressure sound. (1W / 1m) blank.gif107 dB
blank.gifAngle dispersion (green / sun) blank.gif 40 ° / 90 °
blank.gifCoil diameter blank.gif34.5 mm
blank.gifMagnet diameter blank.gif120 mm
blank.gifcutting blank.gifaccording to flag
blank.gifMounting depth blank.gifaccording to flag
blank.gifdimensions blank.gifØ 120 mm x 85 mm
blank.gif Weight blank.gif1.8kg
PDF Download
Colissimo - TNT - SoColissimo
