MONACOR MRD-180 80W Horn Speaker Driver High Midrange 80W 8 Ohm Ø2.5cm
Compression Monacor MRD-180 1"
Reference : 1519
125,00 €tax incl.
104,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Medium-high frequency motor, 80W MAX, 8 Ω.
High-performance, high-performance, professional-grade, high-performance, professional-quality, professional speaker with 12 "and 10" woofer. Replacement SP-30PAX / VC is available as an option, the acoustic values are given for a combination with the MRH-200 horn.
Specifications Speakers
Impedance (Z) 8 Ω
Resonance frequency (fs) 800 Hz
Maximum bandwidth fx-19000 Hz
Crowds. cutoff (fmax.) (12dB / oct.) 1800 Hz
Maximum power 180 WMAX
Nominal power (P) 80 WRMS
Pressure sound. (1W / 1m) 109 dB
Angle dispersion (green / sun) according to flag
Coil diameter 44.4 mm
Magnet diameter 130mm
cutting according to flag
Mounting depth according to flag
dimensions Ø 134 mm x 58 mm
Weight 2.75 kg
Speaker Power (W RMS)80.0
Speaker TypeHorn loudspeaker
Impedance (Ω)8
Loudspeaker diameter (mm)25.0
