MONACOR MHD-55 Horn Speaker Tweeter 30W 8 Ohm
Haut-parleur à pavillon Monacor MHD-55
Reference : 1524
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
8 Ω horn speaker
Pavilion PVC, good performance. For universal professional use. Optional replacement coil (MHD-1255 / VC).
Impedance (Z) 8 Ω
Resonance frequency (fs) 2000 Hz
Maximum bandwidth fx-15 kHz
Crowds. cutoff (fmax.) (12dB / oct.) 3000 Hz
Maximum power 55 WMAX
Nominal power (P) 30 WRMS
Pressure sound. (1W / 1m) 103 dB
Angle dispersion (green / sun) 45 ° / 90 °
Coil diameter 25 mm
Magnet diameter 80 mm
cutting 240 x 80 mm
Mounting depth 187 mm
dimensions 269 x 101 mm
Weight 1.05 kg
Speaker Power (W RMS)30
Speaker TypeHorn loudspeaker
Impedance (Ω)8
Loudspeaker diameter (mm)80.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)103.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)15000
