Audio Isolation Transformer Ground Loop RCA
This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be achieved without distortion.
4.5 / 5
Reference : 13755
45,90 €tax incl.
38,25 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Transformateur Audio d'Isolation Boucle de Masse RCA
This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a large transmission distance to be achieved without distortion. To do this, the circuit integrates a unique impedance conversion and spectrum isolation system with anti-EMI capabilities. In short, this product solves the problems of distortion and noise that can be caused by a long connection or a difference in electrical potential. A 4KV protection system (ESD) is also integrated, allowing to protect the devices connected to the insulator.
SpEcifications
Product typeIsolation audio transformer
Input / output impedance600Ω
Insulation voltage800V
Insulation resistante100MΩ
THD< 0.5% (30Hz - 20kHz), 0.05% @ 1kHz
Crosstalk< 60dB (20Hz - 20kHz), < 70dB @ 1kHz
SNR> 95dB
Protections4KV (ESD)
Housing materialBrushed Aluminium
Dimensions145 x 110 x 60mm
Weight114g
ColorChampagne
2 reviews
Excelent
Solves ground loops without the compromise of sound quality
This review has been posted for Audio Isolation Transformer Ground Loop RCA
son plus propre avéré
Testé sur 7métres , 2 métres en amont et 5 en aval du transformateur . Comparé par rapport à des connecteurs or rca classiques , le son est net et comme nettoyé (audible sans effort) . Au détriment peur être d'une légére retenue non génante ( rodage ?) . A conseiller.
This stereo RCA isolation transformer isolates the audio signal in order to considerably reduce interference and therefore noise. This allows a...
